08-16-2017, 12:46 AM
New engine after 15 years, change mounts?
I have purchased a new Lycoming engine from Van's to replace the original rebuilt O-320-D2A in my RV-9A. The engine was installed close to 15 years ago by the original builder I would assume. Should I also plan on replacing the engine mounts? They look OK externally as far as I can tell.
08-16-2017, 03:23 AM
Absolutely
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
08-16-2017, 03:46 AM
if you go with the Lord mounts, please report a comparison to the old if they were Van's.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
08-16-2017, 04:26 AM
hoses too.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
08-16-2017, 05:51 AM
We're going through a similar update, albeit only 9 years. New mounts, hoses, exhaust gaskets, etc. - pretty much anywhere "new meets old".
08-16-2017, 06:38 AM
So, my Lord mounts are 19 years old
and I'm not noticing any abnormal airframe vibrations (possibly due to a dynamically balanced prop and maybe the P-mags help at low rpm). No goo dripping out of any elastomers.
Should I replace on condition, or only if I have the engine off for another reason? Did my hoses about 8 years ago - all SS over teflon, from SacSkyRanch, so they're probably okay.
It's sad how much this plane sits now that I'm building again, and have a young family of 4 that prefers to travel together vs. Mom and Bill running away for the weekend. I think I'm at 8 hours year-to-date.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
08-16-2017, 10:22 PM
Just about any rubber part FWF will be toast in 10 years. Heat, vibration and ozone all take their toll. A new set of mounts is cheap insurance.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
08-17-2017, 09:43 AM
How will I know I have a vibration mount problem if I'm not feeling abnormal vibrations? Insurance against what occurrence?
Just want to learn, and be wise.
Bill Boyd
08-17-2017, 11:19 AM
Bill, the following document has useful info for inspecting our engine mounts:
http://lordfulfillment.com/pdf/44/PB...tsBrochure.pdf
Joe
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
08-17-2017, 11:26 AM
From the Mother Ship
If they appear to be OK, i.e. rubber is not hard/cracked/delaminated, it?s most likely OK to use them. There are plenty of mounts out there that are 25+ years old and still in service.
Van's Aircraft, Inc.
14401 Keil Rd NE
Aurora, Oregon 97002
503.678.6545
