Old 08-15-2017, 05:20 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Default WTB 2.25" digital voltmeter
The vans analog gauge in the -8 has gone loco. Any suggestions?
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 08-15-2017, 05:26 PM
darata darata is offline
These are popular:
https://buy-ei.com/portfolio/va-1a-voltammeter/
It will monitor volts and amps, either internal or external shunt.
Dave Arata
Sales/Support
Electronics International
Old 08-15-2017, 05:27 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Ed
I might have a old "new" Mitchel gauge still in the box on my shelf in the garage. Then again it might be the Amp gauge. I'll take a look when I get home and get back to you.
UPDATE: Sorry it is the amp meter not volt.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 08-15-2017, 06:25 PM
snopercod's Avatar
The Davtron M655 5-in-1 gauge is handy. Volts; OAT-F; OAT-C;-P-alt; D-alt. You have to wire it to your altitude encoder.
(2020 dues paid)
Old 08-15-2017, 06:58 PM
Originally Posted by darata View Post
Looks nice, but pricey! Especially since I don't have a shunt in my plane so can't use the ammeter function, and rewiring to add a shunt is a pain.
Thanks, though!
Ed
Old 08-15-2017, 07:00 PM
Originally Posted by snopercod View Post
Again, nice but would require new wiring and pricey. All I need is a voltmeter...
Thanks!
Ed
Old 08-15-2017, 08:03 PM
Are you willing to make an adapter plate?
http://www.ebay.com/itm/HS-12V-Water...53.m2763.l2649
Hundreds of other options, if that one doesn't do it for you.
Old 08-16-2017, 04:44 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Default Flight Data Systems GT-50 $165
http://www.aircraftspruce.com/catalo...htdatafc50.php
The GT-50 is a Six Function: Accelerometer - Clock - Voltmeter
G-Meter:
Continuous Instantaneous Display to +12/-10 G?s
Records and Saves Max and Min G's
30 Degree (Sonex) Tilted Panel Compatible
Flight Timer: Automatically Records Flight Time
Clock: 12 or 24 Hour Format
Timer/Stopwatch
Voltmeter
Connect to ground and power - done!
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 08-16-2017, 09:52 PM
AJ85WA's Avatar
AJ85WA AJ85WA is offline
Default I got this one, love it
http://www.mglavionics.com/html/infinity_singles.html
AJ Wessels (Perth Australia)
Completed - RV6
http://rv6aj.wordpress.com/
