Ok, I looked at my right wing, the one that I've closed up. It looks like I can access the pull string by opening up the landing light lens and removing the landing light to make the connection of the additional wire. I know when I installed the LL, it was a very tight fit getting the LL and lens into place and I made the job easier by installing through the wing tip which I hadn't installed at that point. I have a feeling that I'll need to trim my lens and/or the hole in the leading edge of the wing in order to reinstall. I'm wondering if anyone else has experienced problems removing the LL? Otherwise, an access hole would need to be cut underneath (don't want that). Hopefully Van's will have updated plans and a sub kit soon for installing the second LL and additional wiring. Thanks for the help!
RV12 - building
Empennage finished
Wings finished
iS Fuselage in progress
ULS Fuselage kit - SOLD
Farmer - corn & soybeans
Firefighter
Knoxville, IL
