Old 08-14-2017, 11:42 AM
David Fuchs David Fuchs is offline
Default RV-12 Build Order
I am planning on building the RV-12 soon. I will start off with the Empennage/Tailcone kit. I want to order the Fuselage Kit second. Can anyone please tell me what parts for the fuselage kit are normally shipped with the Wing kit and need to be ordered separately to complete the Fuselage?
Very Respectfully
Casualobservertwo@msn.com
Old 08-14-2017, 01:08 PM
rvbuilder2002's Avatar
There are no fuselage parts shipped with the wing kit on an RV-12.
What the plans specify is that you do a fit check of 4 fuselage parts to parts on the wings while it is being built (that is why the wings are recommended to built before the fuselage...... you then already have the parts needed).
Some people just ignore that recommendation, and others order the wing parts in advance of receiving their wings.
Scott McDaniels
Hubbard, Oregon
Old 08-14-2017, 01:28 PM
AeroDog AeroDog is offline
The stub spars come to mind.
Jerre
Empennage, fuselage and wing kits complete
Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2020
Old 08-15-2017, 08:58 AM
sandpiper sandpiper is offline
I built fuselage before the wings but I had the wing kit on hand. So, no problem.
I had no reason to do the fuse first, just decided that's what I would do. Maybe just wanted a cockpit to sit in and make airplane noises!
John Horn (donated for 2020)
Independence, OR
LSRM-A, CFII
Rotax Service, Maintenance, and Heavy Maintenance Trained
Building an RV-12, N7878H reserved
Flying a Flight Design CTSW
