Originally Posted by DanH
Listen to Ernst.
Sandwiching fiberfrax doesn't make much difference when hanging bolted sub-assemblies. The major exception would be the motor mount.
However, riveted joints should always be metal-to-metal. Besides, it's best if the rivets are under the protective shielding...they're aluminum.
Thanks to you both! I'll rivet the oil cooler directly on to the firewall and shield the rivets with the fiberfrax + stainless.
Dan, on your plane did you end up shielding the rectangle inside of the oil cooler mount as well? Since I'm doing this on new install I imagine the best route here is to
- cut the fiberfrax to the entire shape of the firewall, but cut flaps in the places where the oil cooler needs to mount
- attach the frax and stainless
- fold up the flaps to expose metal for the oil cooler, rivet, then attach the folded-up-flaps back down over the newly riveted joints.
This would provide the most coverage. Am I on the right track?
