08-03-2017, 07:03 PM
Originally Posted by DennisRhodes
Our 2000 ft x 50 wide in Northwest Ga is primarily bermuda. The farmer who get the hay on the balance of the filed uses pre emergent in the EARLY spring . That seems to kill out the weeds. We have no irrigation so rainy spring produces great grass and dry seasons can be hard on it. bermuda likes to be cut and does not grow tall or spindly. The worst enemy is "Dallis Grass" may not be the official name but is a blade grass that grows in clumps and will take over the bermuda if not sprayed with 2 -4 D . It Is a constant battle when really wet. As for cutting usually every 8 to 10 days down to 2 inches.
In the early spring I put 2 or 3 20tn dump trucks of sand material from a local wash plant ( has Zero mineral growth value) and drag in with a tractor and cross tie type drag. Fills in the washboard effect and bermuda grass loves it. If I could put in a picture of it I would !!! sent me a text 7708 two three3426 and I'll will return a picture for interested persons.
4800 x 80 in central MS. Ours is bermuda, too, and our primary invader is also 'dallas grass', due to how common it is on the surrounding land (yards). We use MSMA (or the generic replacement), typically a few weeks after the dallas grass has gotten going.
If you have much clay (we do), and you don't have a good crown, it'll likely be soggy for days after a rain.
Best advice so far is to contact the local state/county ag agent. Bermuda is great (good root structure; doesn't grow too fast; stays relatively low) if your climate will support it, but it's not going to work everywhere.
Charlie
08-03-2017, 07:32 PM
Yes, Bermuda is good. But it requires a lot of water. And it likes to be mowed often (every 3rd day), and short, around 2 to 2.5".
Our runway has some of this on the south end. The runway is flat here. It is sloped a bit on the north half, with excellent drainage. The soil does not hold enough water to support Bermuda on our north half.
Good, frequent mowing is the best defense against weeds. Plus, when it's all mowed (weeds and all), it looks pretty darn good!
08-04-2017, 05:37 AM
That right there may have been the post worth the whole year of VAF donations for me. Hop-Along could always use some mogul conrtol, and I was never sure a vibratory roller was the right answer.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
08-04-2017, 06:09 AM
In the early spring I put 2 or 3 20ton dump trucks of sand material and drag in with a tractor and cross tie type drag. Fills in the washboard effect and bermuda grass loves it.
I agree the Bermuda grass loves sandy soil. Mower blades are not so lucky. My farm has relatively sandy soil and it eats a set of heavy duty mower blades every season.
08-04-2017, 06:32 AM
I change the blades on my push mower two times each mowing season. And this is for my personal lawn, 419 tiff Bermuda (fairway grass).
My mower shop recommends buying new blades vs. sharpening the old ones. Not that much cost difference.
08-04-2017, 06:39 AM
Originally Posted by rv7boy
Also, I thought it would be a good idea to crown the runway so the water would run off to the sides.
I have a friend that put a decent crown on his grass runway. Early one morning I flew in with plenty of dew on the grass. It was a weird experience as I started sliding sideways down the crown. I was just hoping I would come to a stop before getting to the edge of the runway. (I did) I suspect I didn't hit the runway dead center.
08-04-2017, 06:54 AM
As for mowing the bermuda, we never touch it with a tractor or bush hog. Use a Xmark 60 inch mower and cut it in 1/2 the time and great results. Usually start on the centerline and throw all the grass to the outside.
DRRhodes
2020 VAF Supporter
RV9 N908DR
08-04-2017, 07:47 AM
Soil pH is key
You will be on the right track after talking to the local extension office. I have found that the key to managing turf grasses is to focus on the soil pH. If the pH is off, the grasses cannot absorb the nutrients. When I was younger I had a problem with the grass turning yellow and I would add more fertilizer, it would green up for a few days and then go yellow again, I had the soil tested and the pH was 3.4. I had to add 1 ton of lime per 1000 square feet to get the pH to neutral (6.8-7.0). Because of all the nutrients that I had added were locked up due to pH, when the lime was added it released it. I had to cut grass every day for a month or more. If I missed a day due to rain, I had to cut it twice the next day. Lesson learned! Once you get the pH right and add nutrients, the grass will choke out most weeds.
08-04-2017, 02:23 PM
We use a BobCat 61" mower. It does a real nice job. I posted several photos here.
