Old 08-03-2017, 09:07 AM
JimMac JimMac is offline
Question Gear leg braided brake line
The braided brake line on my RV-12 seems very tight where it has to bend a little to connect to the caliper fitting. The brake line is so stiff and wedged in so tight between the trailing edge of the gear leg and the caliper fitting that it seems that it would impede the caliper from moving on the pins. Has anyone else had any problem with this? I have had to replace my worn-down brake shoes after only 82 hours of use. My right brake pad was dragging and always trying to turn right (at about the 70 hour point). Would it cause harm if I tried to put a permanent bend in the brake line just above the fitting that attaches to the caliper to relieve the "wedged-in" effect?
Jim McCarter
Madison, AL
RV-12 N864RV 90 hrs TT
Donation Made for 2019
Old 08-03-2017, 10:08 AM
DHeal DHeal is offline
Be sure that there is no physical interference between the aft end of the inboard wheel pant attachment bracket and the aft-inboard corner of the brake caliper. If there is such interference, the brake caliper/linings may not wear evenly.
Also, be sure that your caliper guide pins are clean and free to move (albeit somewhat stiffly). MATCO suggests that no lubricant be used on these pins to avoid attracting grit. I typically clean the pins and sparingly apply a touch of "dry" lubricant (e.g., Boeshield, graphite, silicone, etc.).
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 08-03-2017, 10:36 AM
rvbuilder2002's Avatar
Wont help resolve your problem but just a general comment...
A standard build RV-12 doesn't have braided hose brake lines.
Scott McDaniels
Hubbard, Oregon
Old 08-03-2017, 11:43 AM
Jim do you have sufficient slack in the hose at the caliper for the caliper to move freely?
Tom
Ridgeland, SC
Old 08-03-2017, 11:55 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Also, do not install gear leg bottom tie-wrap too close to the caliper. Bottom of braided hose needs to float. I'll take photo of my installation next time I fly.
Jim Stricker
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 622
Old 08-03-2017, 01:27 PM
Default Gear leg braided brake line
Thanks for the responses, David, There is no interference between the wheel pant attach bracket and the caliper. Scott, I realize the standard RV-12 has the aluminum tube with the loop, but the builder of this plane (who I bought it from) had put these lines from TS-FlightLines on. These look like high quality lines but I may fabricate the aluminum lines with the loop and put those on. Jim S., I would be interested in seeing a photo of yours. Like I said in my initial post, The problem seems to be in how the tube was wedged between the trailing flat surface of the gear leg and the caliper attachment. The brake line is simply not going to be allowed to move as the caliper tries to move. Tom from TS FlightLines, No, there doesn't seem to be enough slack. It seems like this braided brake line might work better if it made a loop around the gear like the original design so that it would exert no resistence to the caliper movement. Well, I think I'll put the aluminum lines on as per the original design.
Jim McCarter
Madison, AL
Old 08-03-2017, 02:03 PM
Piper J3's Avatar
I will send pic next time I'm at the plane. Mine pretty much looks like the photos in the installation instructions here http://www.aircraftspecialty.com/PDF...201-4-2014.pdf
Jim Stricker
EAA #499867
Old 08-04-2017, 05:20 AM
Jim---Steve and I have sold a bunch of them for the 12's, and havent heard of any issues. Lets talk and we'll see if we can help you out.
Tom
Ridgeland, SC
Old 08-04-2017, 07:05 AM
BigJohn BigJohn is offline
Jim, suggest you work with Tom and Steve to resolve your issue before reverting to the original lines, which you probably dont have readily available. Those guys are fantastic with their support!
John Peck, CFII, A&P, EAA Tech Counselor, Flight Advisor.
?Master Pilot? Award, UFO Member.
RV-12 N37JP 120176 Flying since 2012.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
Old 08-04-2017, 07:32 AM
Thanks for all the responses. I will call TS flightlines and talk to them about it. If I am the only one with an issue, I may be imagining an issue that really isn't there. When I think about it, I guess the caliper movement is actually very, very slight and maybe my dragging brake was caused by something else. When I first removed the right caliper, The piston WAS stuck in a "braked" position. I'm not sure what caused that. I took it out and cleaned it and put it back in the caliper. I'll put everything back together and keep the braided lines on and maybe everything will work fine. I was probably over-analyzing it. Thanks again. All of your comments were very helpful.
Jim McCarter
Madison, AL
