06-12-2016, 07:23 PM
Garming GSA 28 servo mount RV 8
I'm installing the GSA 28 on the RV 8 wing spare for the roll servo. I wont buy the servo until I'm almost ready to fly (at least 2 years).
I have the servo mount, but it appears to be too long. Do you have to trim it? i didn't see anything in the manual about cutting it down to size. I have the one that is marked for the RV-8. Its probably about 1/4'' too long.
It would be easy to cut, I'm just curious if others have had the same problem.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
06-12-2016, 08:15 PM
DO NOT CUT IT! It is right, download the G3X install Manual, Garmin makes it easy!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
06-12-2016, 11:53 PM
I installed mine and it was a simple exchange for the Van's parts.
There was no modification of any kind required.
I would double check you don't have the bracket for the pitch servo or something else like that.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
06-13-2016, 08:18 AM
I swapped the Dynon mount for the Garmin mount when I installed the G3X system. No mods were required.
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
08-01-2017, 07:17 AM
Where did you guys get brackets for Garmin servos? I saw them mentioned on the Garmin website, but I can't find them listed there for sale.
Rob K
RV-8 N884RA under construction
08-01-2017, 07:42 AM
GSA 28 brakets available at Aircraft Spruce !
Hello !
I purchase my Garmin Autopilot Servos brackets at Aircraft Spruce. I got them 2 weeks ago. I will start installing them today.
Check out this link:
http://www.aircraftspruce.com/catalo...h_11-11440.php.
You will have to select the RV model you want, plus the roll or pitch bracket. they come separately.
Have fun !
Martin Leroux
CPL ME-IFR & CFI Class 3, 1,400+ Flight Hours
Terrebonne, Quebec, Canada
RV-8 s/n #80414
Kitlog: http://www.mykitlog.com/MartRV80414/
Empennage: 100%
Fuselage: 95%
Wings: 99% (Flaps remain to attach)
MD-RA Pre-closure inspection completed Dec 27, 2019
Entering Final Assembly Phase !
08-01-2017, 08:02 AM
Thanks! It seems pricey for what's in those kits, but I'm sure it would take me hours and hours to fabricate something similar.
Rob K
08-02-2017, 06:06 AM
RV4 kit ?
While we are on this subject, can anyone share what kit to use for RV4 ROLL servo ? Garmin G3x help desk could only say the universal MIGHT be correct.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
08-02-2017, 07:06 AM
I have SteinAir bookmarked for my roll servo mount. Left wing almost done but do not want it sitting around till able to mount it.
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
