Originally Posted by BigJohn
Pull the instrument compartment cover, find the AOA port on the back of the Dynon, follow the tubing.
Sorry, didnt pick up on the fact this is a Skyview. David is right. That makes it a lot harder to get at the end of the tubing, if indeed it is there.
Is it possible to contact the original builder and just ask about the AOA?
If not, how about pulling the wing pins and sliding the wing(s) out a few inches to see if there is tubing?
Basically I agree with Tony. Shut off the distracting noise and figure it out at the next condition inspection. AOA really not necessary in this little airplane, unless you are dragging it into very short strips on a regular basi. JMHO.
