Old 07-23-2017, 11:04 PM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default NTSB report for N306AB
Just reviewed the report...
Is this a glaring inaccuracy?
"Control continuity was established from the cockpit controls to the elevators and the right aileron. The left aileron controls cables were fractured and had a splayed, broom-strawed appearance, consistent with tension overload"
Since when has an RV7 had control cables for the ailerons?
Don
RV-8 build
DONE!
C-GLOV
http://www.mykitlog.com/Don%20Patrick
Old 07-23-2017, 11:55 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Indeed
Indeed it seems like an error. http://www.vansairforce.com/communit...d.php?t=151645
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 07-24-2017, 06:33 AM
Jeff kudlo Jeff kudlo is offline
The Aircraft and Owner/Operator Information portion of the report listed total time of 258.9. Of interest is the report also indicated "The last documented inspection was a conditional inspection that was completed on May 15, 2015, at an airframe time of 258.9 hours."
Blue Skies & Grateful Thanks,
Jeff
November Seven Victor Quebec
166 hours
Old 07-24-2017, 07:47 AM
Snowflake's Avatar
Apparently the continuity department didn't review the report before it was released.
Rob Prior
Old 07-24-2017, 11:02 AM
BillL BillL is offline
It is N307AB.
Bill
RV-7
Lord Kelvin:
Old 07-24-2017, 11:37 AM
NavyS3BNFO NavyS3BNFO is offline
Don
I noticed the same thing. Unfortunately it makes you question the accuracy of the rest of the report.
RV-8 empennage DONE
Wings 99% done
Fuselage in progress
Old 07-24-2017, 11:44 AM
Default Action taken: Correction underway.
http://www.vansairforce.com/communit...28&postcount=5
Bill
RV-7
Lord Kelvin:
Old 08-01-2017, 08:25 PM
Sue Sue is offline
Default Accident
N number? Is it 306AB or 307AB? Two different N numbers on report?
