Old 07-19-2017, 12:57 PM
russe russe is offline
Default Cracked lower cowl attach bracket
Anyone seen a problem like this before?
I found the problem during maintenance for an unrelated issue. I guess I got lucky.
Russ
Old 07-19-2017, 12:59 PM
TFeeney TFeeney is offline
Cant see the picture
RV10
QB Wings done
Fuselage done
Systems and electrical...
Old 07-19-2017, 01:14 PM
https://photos.google.com/share/AF1Q...RrOF9lcFBfVEpR
Old 07-19-2017, 02:02 PM
n700jl n700jl is offline
Default crack
Yes! I had to double mine up with a piece of angle!
Jon Hubbell
RV-6 Flying IO-320X tip up 500+hrs G3X 2004 Oshkosh Outstanding workmanship award, 2004 Sun N Fun Best Workmanship 2006 Sun N Fun Outstanding Aircraft
RV-10 Flying IO-540-C4B5X 500+hrs G3X 2011 Bronze Lindy Award Winner
"Negative Ghostrider the pattern is full"
Old 07-19-2017, 02:06 PM
Flying again!'s Avatar
Flying again! Flying again! is offline
I found the same thing at about 450 hours - TJ
RV-10 N331JH 3rd owner (First flew in 2005, #15 flying)
Northwest Regional 52F
Old 07-19-2017, 02:14 PM
bill@fusion4.net's Avatar
bill@fusion4.net bill@fusion4.net is offline
Yep common problem. Mine lasted 1 year. Cut it flat and rivet on some angle.
Bill Thomasson
RV-10 - Flying - Phase II. 99.8% done... it's never really done!
http://sites.google.com/a/fusion4.net/rv10/
Suwanee, GA.
Old 07-19-2017, 02:33 PM
I guess I don't land as smooth as you; my plane is at 350 hrs...
Thanks for the information and proposed improvement!
Russ
Old 07-19-2017, 03:30 PM
aturner's Avatar
aturner aturner is offline
Mine too. Consider building a bracket that has the vertical support aligned with the nose gear fairing, instead of offset by 3/4". I would post photos, but well, that just isn't working out for me anymore.
-Andy Turner
RV-10 N784JC
Old 07-19-2017, 06:24 PM
Dorfie Dorfie is offline
I've seen this in a friend's RV10. I reinforced mine from the get go because of that.
I'm theorizing that the hinges at the bottom allows for more movement and might be contributing to the problem. I know many builders, myself included, installed screws to attach the bottom of the cowl to the fuselage.
Any of the broken one's from bottom cowls attached with screws?
Johan
Dorfie
RV10 Flying, N245JM
2020 dues paid with a smile
Old 07-19-2017, 10:36 PM
paul330 paul330 is offline
Whilst I was doing the build, I realized that his part was simply not going to be up to the job. I made a simple mod by doubling up with a mirror image - turning it from a "C" to an "H".
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
2019 Donation Made
