07-18-2017, 02:36 PM
Originally Posted by rvbuilder2002
. . . "Unofficially, the new tank capacity is 20.2 gal.
There was no goal to increase capacity because the better fuel economy of the iS provides more range on the same amount of fuel."
Thanks Scott.
Unofficially, I calculate approximately 50 more minutes of fuel endurance for the 912is RV-12. That's figuring both tanks have a capacity of 20.2 gallons.
07-18-2017, 03:04 PM
Originally Posted by Driftdown
Thanks Scott.
The official capacity of the tank in the first version (912ULS) was 19.8 Gal, so the new airplane has almost an extra 1/2 gal.
Scott McDaniels
Hubbard, Oregon
07-18-2017, 03:06 PM
Originally Posted by LettersFromFlyoverCountry
I've always wondered this: When you build a plane, how many people actually work on the building process?
It varies.
Some times just a couple, and other times (as in this case) up to 5 at some points.
Scott McDaniels
Hubbard, Oregon
07-18-2017, 03:36 PM
Thank you.
Recalc in progress!
New numbers . . .
Unofficially, I calculate approximately 55 more minutes of fuel endurance for the 912is RV-12. That's figuring old tank capacity and new tank capacity, at cruise fuel flow.
In my humble opinion, I'd say that is significant for the RV-12.
07-18-2017, 03:56 PM
Anybody know if the new tank can be used with the old fuse?
07-18-2017, 04:06 PM
Filler neck not in same location - more underneath window. In fact, looks like more difficult to fuel from handheld cans because location is more over center of wing.
Jim Stricker
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 618
07-18-2017, 04:10 PM
Yah... right now I can put a furniture pad over the top of the fuse, set the can on top and let it fill the tank. With the new location I'd either need to pump it in, develop better biceps or work out some sort of hose arrangement... not sure how that would work out. Probably more convenient if you fill up from a gas pump, but a lot of us schlep it in 5 gallon cans.
Dale
Omaha, NE
Previous RV-7 project (sold)
07-18-2017, 04:14 PM
Use a "jiggle tube" directly to the new fuel port.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
V AF donation through June 2021.
07-18-2017, 05:25 PM
Looks great, love the electric flaps and the center console, I really wish they had moved the fuel to the wings, still the only item on this aircraft I don't like.
Built, RV 8, RV8A, RV 10, RV12, Purchased RV7A
Restored J3Cub and PA28R180
Pecan Plantation
Eagles Nest Mentor
EAA Tech Counselor
07-18-2017, 05:40 PM
I figured an iS powered -12 must in the pipeline a couple years back. The economy gains along with less maintenance and carb fiddling is clearly what the people want these days. The time will come soon where no more carbed 912s are being produced.
One of our Rotax vendor shops no longer builds custom 912s with carbs any more as of a couple years ago. They work so much better with EFI.
Glad Van's was listening. I predict more sales as a result, despite the higher price of the engine.
