Old 07-12-2017, 07:10 AM
sritchie sritchie is offline
Default How to dimple nutplate holes on already installed firewall?
Hey all,
Technique question that I haven't been able to track down on the forums. I've laid out my firewall and drilled all primary holes for cable and wire passthroughs. I'm going to drill nutplate holes today, and I'm NOT looking forward to trying to dimple the nutplate holes in stainless steel using my pop rivet dimpler set with copper nails.
Any recommendations? For the holes near the top of the firewall I'm going to muscle the DRDT-2 up in the air and have a partner work the lever.
For the lower holes where I can't do this, I was thinking of using oops rivets and giving a tiny countersink to the steel with my deburring tool. This will PROBABLY work... but are there any "better" solutions out there?
Thanks all!
Old 07-12-2017, 07:26 AM
TFeeney TFeeney is offline
Cleaveland sells a set for your rivet gun that holds the dimple die. Drill a hole in your steel bucking bar (not the good tungsten one! ) and you can now dimple anywhere a rivet gun will fit. It works well.
http://www.cleavelandtool.com/401-Ri.../#.WWYi7ITyu9I
RV10
QB Wings done
Fuselage done
Systems and electrical...
Old 07-12-2017, 07:28 AM
Yes, amazing! I just placed a cleaveland order for some glare shield material 10 minutes ago. I'll send them a note and add this piece to the order.
Thank you!
Old 07-12-2017, 07:36 AM
rv6builder's Avatar
rv6builder rv6builder is offline
Definatley a nice looking tool- I'll have to make or buy one myself. I've been using the same idea but with a hammer instead of a rivet gun. Just make sure both sides are held perfectly straight! I made a couple ugly dents but at least they are in a spot thay doesn't show.
Cheers
Alex
Alex Doughty
Canadian ATPL
Flying!!
Old 07-12-2017, 07:59 AM
cczarnik cczarnik is offline
Just for reference, this is the same part that is in the bottom of the C-Frame. So many folks may already have one of these in the shop-
Chuck
7a emp complete, wings underway
VAF Dues paid - 2018
Old 07-12-2017, 08:11 AM
scard's Avatar
scard scard is online now
Yep. Works great. We call it kamikaze dimpling for the reasons already mentioned. One of Tanya's least favorite things to do. No margin for error .
Scott Card
CMW E-Lift
Old 07-12-2017, 08:34 AM
sjhurlbut sjhurlbut is offline
Default Why
Why not use the pop rivet dimpler? You can get non copper nails. Works great I think.
Originally Posted by sritchie View Post
Hey all,
Thanks all!
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - building
Old 07-12-2017, 08:39 AM
rvsxer rvsxer is offline
Yes the firewall is stainless steel, but it is very malleable. You'll find that out if you push too hard when drilling a hole. Try the pop rivet dimple tool first, and use a steel finishing nail with it.
Mike Hilger
RV-6 N207AM w/G3X, 1,600 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
flion's Avatar
flion flion is offline
Not in MY Avery C-Frame. I just have the set holder. However, a machinist friend of mine made up one of these from an old spare set in a few minutes for me. To use effectively, both 'gunner' and bucker should use more force than when riveting and the guy on the trigger should be quick to prevent the sets from bouncing away from the hole. I've also had good luck (and more control), using the Avery upper set holder with a set and a dead blow hammer.
By the way, the easiest mod for the bucking bar is to drill a hole to accept a regular set, which can be put in an unpolished face of any steel bucking bar you have (in case someone thought you needed to machine a female set into your bucking bar to match the male set; TFeeney's post may not have made that clear).
EAA Technical Counselor #5357
Old 07-12-2017, 08:47 AM
I did find that out when pushing too hard
Any tips on flattening out larger holes that have been bent inward slightly?
