Old 04-13-2007, 01:30 PM
kevinsky18's Avatar
kevinsky18 kevinsky18 is offline
Default RV-8 simulator for flight sim 9 or X
I have found a decent rv-7 add on and a poor rv-8 add on for Microsoft Flight sim 9 and X.
Does anyone know of a really good RV-8 add on? If so a link would be great.
If not, anyone here interested in making one?
Old 04-13-2007, 01:35 PM
Hostage46's Avatar
Hostage46 Hostage46 is offline
Were did you find the 7? I saw a pay site but was afraid it wouln't work in FSX
N872P (Reserved) VAF#771
RV-8 Tail Kit
Old 04-13-2007, 01:49 PM
N258RE N258RE is offline
see here:
http://www.vansairforce.com/communit...ad.php?t=12825
RV-8
flying
Old 04-13-2007, 01:51 PM
xavierm xavierm is offline
Default it kind of works
I have it. It kind of works. The guages won't display though. I've been planning to fix it but haven't gotten around to it tet.
I think it's $8.00 but the company who makes it is going out of business. Might not be available anymore.
_____________
Xavier
RV-7 build in progress
www.theaviatorx.com
"Genius is persistence in disguise"
Old 04-13-2007, 02:52 PM
Pirkka Pirkka is offline
http://www.flightfactory-simulations.com And the page says that they will close at end of this month. I had already forgotten this one as there was another RV-7 model coming also... but 8 bucks ain't much.
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
Old 04-13-2007, 04:06 PM
RVAddict's Avatar
RVAddict RVAddict is offline
Default RV for FS 9 (2004)
I've found an -8 and a -4 on simviation. If you google "flight sim 2004 downloads" it will show up. I've never payed attention to the URL, sorry .
The -8 is probably not that accurate, as it seems a little twitchy and hard to control to me. But the -4 flies really well. They both have VCs but I don't use them on either one of those planes b/c the regular panel looks better. I'd be interested in finding more of the RV series for fs 2004. The -4 and -8 are my favorite but I'd like to have one of every RV model on my sim!! Hmm, wouldn't everyone?
"Shake the hand that shook the world" - Walter O'Dim
Old 04-13-2007, 04:16 PM
kevinsky18's Avatar
I wouldn't mind learning how to make the planes. The only problem would be that I don't have a flying RV-8 so I would have a hard time modeling the flight characteristics.
Old 04-13-2007, 04:43 PM
Default Most probably aren't accurate
I think most of the aircraft that are available for Flight Simulator are accurate. The Dreamfleet/Flight1, and Abacus aircraft come to mind as ones that are probably real close. I'm sure there are other companies that produce good models.
I know people who "correct" the flight characteristics of aircraft then distribute them but have never flown the real aircraft. hard to correct something when you don't know how it flys.
_____________
Xavier
www.theaviatorx.com
Old 04-13-2007, 05:28 PM
RVAddict's Avatar
Yep, the gauges won't display on mine either, I just downloaded it. It looks like an awsome plane, and I tried flying it around the patch, but my pc is too slow to run it I guess. I kept getting "hitches" in the screen. I even tried turning down the scenery. If you get the gauges fixed will you please pm me and tell me how or whatever? I wish I knew how to work on these files, build my own airplanes, ect, but sadly, I consider myself lucky to get one out of ten aircraft that I download to even work on my simulator if they don't come with an installer.
Josh
UPDATE: The first time I loaded it up I had the gauges for about 5 seconds and they all dissapeared. The second time I loaded up fs 2004 they were all there but slowly dissapeared 1 by 1 until I had no gauges left. Also, you cannot manupliate any of the toggle switches on the panel, even though the little finger pointing hand comes up there on something you're supposed to be able to change!!!
Old 04-13-2007, 06:31 PM
kevinsky18's Avatar
Here is a link to a free RV-8 sim.
Be warned it's a poor job but hey it's free and the install was easy. Just unzip it into your flight sim main root directory and start up the game.
http://library.avsim.net/esearch.php...CatID=fs2004ac
