Old 07-09-2017, 03:30 PM
sritchie sritchie is offline
Default Doubler needed for 120mm defrost fans?
Hey folks,
I've decided to install 2 120mm defrost fans in a spot very similar to Brian and Brandi's:
Do y'all suggest installing a doubler around these holes on the underside of the skin? An .032" doubler with a single row of rivets and corner holes for the #8 screws doesn't feel overkill, but a 1" thick doubler like Vans suggests for the radio stack hole DOES feel overkill.
What are other people installing here to support their fans?
Old 07-09-2017, 04:52 PM
climberrn's Avatar
climberrn climberrn is offline
Pretty large fans. Mine are much smaller, and lighter and don't see any need for a doubler. Don't need to move much air to be effective.
Joel
N626JA
RV-7A at CXP
Flying!
Old 07-09-2017, 05:38 PM
cajunwings cajunwings is offline
Default Doublers
I installed fans this size in 2 different Slider 9's. Since I wasn't able to do the structural analysis myself (and it is structure) I used the repair patch part of 43:13 as a guide. The doubler was about 1" wide and got a double row of flush 3/32 rivets. Also made my own "grille" by drilling a hole pattern in a square of .032" which will add in a bit of strength as well. If I'm going to go off the plans a little overkill that hardly weighs anything works for me.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 07-09-2017, 06:46 PM
Default Fans
I used the 120s and put a 1" doubler in place with flush rivets...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 07-10-2017, 09:44 PM
I ended up doing this as well, with a 0.75" doubler to accomodate the fan flange. Here's the result:
It was obvious when I finished sanding out the cut that it needed a doubler. With just the doubler it's nice and still again, and especially with the fan in place it feels great. Thanks all!
Old 07-11-2017, 08:37 AM
DRMA DRMA is offline
I also installed 120mm fans in this location. I purchased the mounting plates shown at: https://www.newegg.com/Product/Produ...0009-_-Product
This grill made for a very easy install, and comes with both a very solid square aluminum plate (doubler) and a nice grill to fit the round hole. I used flat head screws to mount the plate, and can either leave it open for natural ventilation, or can mount the fans for forced ventilation which is my intent.
Dave Macdonald
RV-10 First Flight April 1, 2020. Currently in Phase 1
2020 VAF Dues Paid
Old 07-11-2017, 09:32 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Default No grill, no backing plate option
An option is to not use a grill at all, just drill an interesting pattern of holes in the glare shield instead of one big square hole. This strengthens the area so no backer plate is needed, and eliminates the ugly grill.
Sorry, didn't set up for photos but is anyone wants them PM me your email address.
Carl
Old 07-11-2017, 12:08 PM
Carl
+1. This is what I did. No flex in the glare shield. (In the -10 this is best done prior to installing the windscreen, depending on the exact location of the fan).
Old 07-11-2017, 12:36 PM
Raymo's Avatar
Raymo Raymo is offline
Carl
+2. Drilled some holes for airflow.
Ray
Old 07-11-2017, 01:24 PM
vernon smith's Avatar
vernon smith vernon smith is offline
Carl's fan install
