  #11
Old 06-27-2017, 07:47 AM
Mich48041 Mich48041 is online now
Mike knows what he is talking about. Listen to him.
Joe Gores
RV-12 Flying
Old 06-27-2017, 12:56 PM
bob1393 bob1393 is offline
Thanks guys I appreciate all the comments. As there are 3 of us who own this plane together, it makes the cost of the VR about $60 each. We will no doubt continue to use the Ducati VR, wired per Van's plans, and just hope we can get a longer life with them, as some others have had.
Bob
Old 06-27-2017, 01:12 PM
DaleB's Avatar
DaleB DaleB is offline
Originally Posted by MMiller View Post
If you have a pre 2010 regulator, it will fail because of INTERNAL cooling design issues, if you run these at low power, they will last forever.
If you have a 2010 or later version it will likely fail from operational vibrations acting on manufacturing induced, prestressed component leads, in a potting compound that is temperature unstable.
Anyone who tells you the failures are caused because Vans didn't follow the Rotax required wiring plan doesn't know what they are talking about, they don't have a clue to how this regulator works.
Mike
Mike, I have one with a fairly hard, light green potting compound. The plane was completed in late 2011, but I have no idea when the FWF package was purchased. Any idea of a solvent that will work on this stuff? I'd like to get the PCB out and touch up the solder joints. So far it's coming out in crumbly chunks. I've got the bottom of the board mostly exposed, but no luck getting further than that.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 06-27-2017, 01:27 PM
bajapilot bajapilot is offline
Mike,
That makes sense to me since my Rans is glass smooth and my 12 feels somewhat buzzy. I just figured that was the difference between a tube fuselage and 10K pieces of aluminum flying in formation. Do you think it would help to use rubber vibration isolators to mount the VR? Mine with 212 hours is starting to get sloppy with voltage control.
Old 06-27-2017, 03:07 PM
MMiller MMiller is offline
Dale, you have a pre 2010 version, that's how those come apart. It will have PN 343620 stamped on it. The date code is above the word DUCATI, the first two digits are the year, I'm not sure if the second two are month or production run of that year.
These are not repairable, mostly because you can't fix the design issue, but there is a workaround. These fail from diode/plate separation. The inability to adequately transfer heat to the case causes the diodes to unsolder themselves. You can add a 35-50 amp 1000v bridge rectifier externally and jump the the two A/C pin to the regulator G terminals and jump the + pin to the R & B terminal. The bridge - pin is unused. This bypasses the damaged connections and moves half the heat out of the regulator.
If the connector is good, you could Install a new PCB and rework it like a current version regulator.
Bajapilot, I don't know if that will help, and I doubt it will hurt. Vibration is only one part of the problem. You still have prestressed component leads and a potting compound that is too soft and unstable. If you try this, you must ground the regulator case to the airframe.
Mike
Old 06-27-2017, 03:37 PM
DaleB's Avatar
4-digit date code is most likely a two-digit year and two-digit week, from 01 to 52. Thanks for the tip about using the half bridge... I can see how that would work. Not a bad idea, as long as the SCRs are good.
Dale
Omaha, NE
Old 06-27-2017, 08:43 PM
DaleB's Avatar
Yup, month and week is the industry standard, but in all the regulators I've seen, the second set of numbers never went higher than 10....maybe Ducati doesn't follow industry standards.
It's Italy. Maybe they only count work weeks.
Dale
Omaha, NE
Old 10-09-2017, 02:36 PM
K0TS K0TS is offline
Default Silent Hektik regulator F4118 for sale
I have one brand new SK voltage regulator, which plugs into the RV12/Rotax 912 for sale. https://www.silent-hektik.de/UL_R_912.htm
I ordered two for my RV12, installed one and have the second for sale.
I'd like $300 shipped to ConUS
thanks
joe
Ok guys... The regulator is sold..
thanks
joe
Old 10-09-2017, 03:28 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
PM sent ............
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 630 Hrs on the Hobbs
Old 10-21-2017, 04:28 PM
ramrod25 ramrod25 is offline
Would recommed NAPA Part# SME 7068102
About $100 bucks
Mount on cockpit side of firewall with a 12V computer fan blowing on regulator.
My fan is about 5" diameter wired to master switch.
Have been flying with this regulator for 18 months with no issues after my ducatti burned out.
Heat is the enemy of these regulators.
Regards
Ramrod25
