Old 06-20-2017, 12:29 AM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
Default Lightspeed Zulu V1 - COMM mic feedback whine?
Aviators,
I started getting a Mic feedback whine during transmission, go read here http://www.vansairforce.com/communit...d.php?t=150448, then finally traced it to TWO of my Zulu 1 headsets.
In this thread I want to understand if you guys experienced the same with Zulu V1 headsets?
Background:
I have 4 x Zulu V1 headsets: (2 bought in 2008, and 2 bought in 2011)
The 2 bought in 2011 with the newer microphone design, BOTH of them, started giving me serious mic Feedback Whine when I transmit on both my COMM Radios. If I switch OFF the headset ANR the feedback whine disappears. Normal cockpit conversations are fine without the whine. They both effectively are unusable during transmission.
In comparison the 2 bought in 2008 with the older microphone design, BOTH of them are still working 100% fine, if i use them in the same airplane as above, there is no mic feedback whine.
I tried all 4 headsets in a different airplane, and still the 2 from 2011, gives Mic Feedback Whine on Transmit.
So there is definitely a problem with my newer models bought in 2011. Even when i adjust the MIC Gain on the Mic boom to ZERO, i get MIC feedback whine.
Photos of Newer Zulu 1 Design with feedback problems (Both of mine). Circular disk Microphone and black holes on top of Speaker Cups
2011 version
Photo of Older Zulu 1 Design, without feedback, working perfectly. Standard type microphone and Silver holes on top of Speak Cups
2008 version
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Old 06-20-2017, 05:52 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default I did -- original Zulu
Finally found, thanks to VAF, there is a mike gain screw on the mike --- adjusted that and pretty much solved the problem --- now I have to reset the 650 to get my sidetone back.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 06-21-2017, 12:14 AM
Ron
Hey Ron, I tried that, and it does not solve my problem.
Originally Posted by RudiGreyling
<SNIP>
So there is definitely a problem with my newer models bought in 2011. Even when i adjust the MIC Gain on the Mic boom to ZERO, i get MIC feedback whine. <SNIP>
What did you do to your 650 to get the sidetone back?
Old 06-21-2017, 05:09 AM
Caveman's Avatar
Caveman Caveman is offline
Rudi, I have the version 1, (just one set) and have had no issues over the past 8 or so years.
Joe
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
Old 06-21-2017, 07:01 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
I had the same issue with my Zulu V2 which uses the same microphone. I contacted Lightspeed and they asked me to return the headset to them. Even though they were out of warranty, they "fixed" the problem and even replaced the cushions. I haven't had a problem with them since. YMMV
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 06-21-2017, 12:24 PM
flightlogic's Avatar
It might take factory intervention as mentioned. I am using those with no problem. I have all the generations of Lightspeed... and they are great for RV.
My customer had a problem in OV-10 Bronco.... which is quite loud. It was solved with leather mic muffs.
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
