Old 06-19-2017, 04:44 PM
DanH's Avatar
DanH DanH is offline
Originally Posted by Larry DeCamp View Post
Dan,
This link says no shipping to US. Any advice ?
Try one of the other 48 choices?
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-19-2017, 06:33 PM
rvbuilder2002's Avatar
Unless they have made some improvement to the plastic flex section under the blue silicone sleeve, I recommend against the Vivida (aka "Ablescope"). The flex section breaks rather quickly.
Just get a cheap camera and tape it to a coat hangar wire.
http://www.tomtop.com/endoscopes-206/
We haven't had any problems with ours but it has only bee used about 10 times or so, so I will be watching for that.
The aim-able camera was worth it to us because we use it for more than just looking at valves in cyl.
Scott McDaniels
Hubbard, Oregon
Old 06-20-2017, 12:04 AM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Default Compressed, or even better, embedded URL's
Charlie,
Have you ever tried Tinyurl?
Your 368 characters are easily reduced to 27 characters like so:
http://tinyurl.com/ya9ehufw
Or better yet, using the hyperlink function in the edit/compose window, the link can be embedded in your text anywhere, like here.
That big ol' long URL (post #2) looks downright scary!
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 06-20-2017, 12:14 AM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Originally Posted by rv7charlie View Post
If you can live without the wireless (wifi) feature, I bought one a few months ago that has a USB/microUSB plug on the end (works with my android phone or tablet) for about $12. Didn't come with the attachments, though. Mine is about 1/8" dia & around 10' long. You can get them with longer cables, if needed.
Charlie
edit: Just google 'usb endoscope', and some variations on that, on ebay or amazon for lots of choices
Are the specs on that Tanga correct? It says the Camera Diameter is 8.4mm but the focal distance is only 3mm to 8mm. So you have to be lest than 1/8" away from something for it to be in focus? Is that actually useful?
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 06-21-2017, 11:52 AM
Originally Posted by rv7boy View Post
Charlie,
Not nearly as scary as a url that I can't see until I click on the link & actually go to the site.
The original reason for shortened link sites was because back in the dark ages many browsers couldn't handle a url that 'wrapped' down to another line. Back then, no one worried about their computer being attacked by a rogue web site.
Just look at the long link, until you see the (dot)com, org, etc to see where it's going. With those shortened redirect links, you can't tell where you're going until you're there.
Charlie
Old 06-21-2017, 11:55 AM
Never paid attention to that spec, but I doubt it's real. Almost certainly a typo, or something that was lost in translation. I don't have direct experience with that particular product.
My $12 model focuses fine out to several inches, and I get usable images out past a foot.
Charlie
Old 06-21-2017, 12:21 PM
MercFE MercFE is offline
Charlie
The long "original" link could be just plain text with a hyperlink embedded that goes to a completely different location. I suggest that you don't take "long links" at gospel.
Old 06-21-2017, 12:48 PM
I'm well aware. I'm also aware that hovering over a hyperlink will show you the actual destination at the bottom of the page (at least if you're using the chrome browser).
Now, go to Don's post with the tinyurl hyperlink, and do your (and my) 'hover' trick, and tell me what you see for an actual destination.
Old 06-22-2017, 05:52 AM
n981ms's Avatar
n981ms n981ms is offline
I'm just happy someone goes to the trouble of posting a link rather than telling me to google it or search the archives.
Maxwell Duke
Kitfox S6/TD/IO240/SteamIFR Built it
RV10 IO540/AFS5600x3 Bought it
CH750 O200/AFS5500. Built it with 7 friends. DAR-Vic Syracuse
Maule M7-235C Sold it(kind of miss it)
VAF paid 5/2017
Old 06-22-2017, 06:03 AM
BillL BillL is offline
True, but pretty much all the work we airplane owners use them for is very close up so the res. is not an issue.
The 640X480 will produce a pretty good quality large sized image of a valve of a cyl wall.
We have a VA-400 in our shop and like it.
Overall I have one and will agree with the value/performance of this device. But . . .
The problem is the range of focus, get closer yields more pixels per inch, but the optical focus gets fuzzy. I have the ablescope and also find the clarity marginal. Color rendering is horrible, but a little understanding overcomes most of that confusion. The main shortcoming is when trying to see cross hatch and polished spots. Maybe that does not happen often, but it is important to me.
Bill
RV-7
Lord Kelvin:
