Question about the NACA controller
If mounted as Ed and others have done, just behind the baggage bulkhead, is there potential for EMI to the ADAHRS units that will be mounted on a tray jsut below the top skin, ahead of the next bulkhead to the rear?
Not so much worried about brief EMI emissions during changes in the valve position, but whether the servo draws significant idle current or emits significant RF when it's awaiting the next position command (i.e. 99.99% of flight time). It will be only about 15" or so from the ADAHARS units, with its control wiring routed forward into the overhead console.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
