  #31
Old 06-08-2017, 01:54 PM
hlangebro's Avatar
hlangebro hlangebro is offline
Are you sure your fuel flow device is calibrated correctly????
H?kan Langebro
San Diego, CA
RV-7A, slider
Lycoming O-320 D1A, 160hp C/S
First flight 6-11-13
Re-engineering a Lancair 320..!
http://www.youtube.com/watch?v=AJuQ68tccTQ
http://www.mykitlog.com/hlangebro/
Old 06-08-2017, 01:56 PM
ALMARTON ALMARTON is offline
Hey folks!
There were a bulletin for this fuel pump:
https://www.lycoming.com/sites/defau...eplacement.pdf
Continued operation of a non-conforming fuel pump can cause fuel leakage out of the airframer?s vent line
or into the engine crankcase.
And that what happened!
Got very lucky indeed so.
My plane despite only 143 hours since new was bought from a professional Company in 8/2015
They never told me about that bulletin despite they have a department just for that...
Alexandre "neck" Marton
Brazil
RV7A (8/2015 built by FLYER)
Lycoming 180 HP - YIO-360-M1B, Hartzell C2YR-1BFP/F7497? 72??, Garmin panel - G3X Touch, GTN650, GTS800, WX-500, BATT CONCORDE RG-25XC AEROBATIC SEALED.
Others: RV9A
Lycoming XIO320-D1A, Hartzell HC-C2YL-1BF/F7663-4 , CS GOVERNOR MTV-12-B, DYNON D180
AND GARMIN AVIONICS
(Sold with aprox 300hrs flown from Dec/2010 -- JUN/2014)
Old 07-03-2017, 08:21 AM
Folks,
Glad to inform that:
1 - After detecting a fuel pump leak and changing it to a new one.
2 - Cleaning injection nozzles
3 - Setting AVSTAR Fuel System to standards
But mainly due to (1) , got the aircraft 30% more economical. 30% reduction on fuel consumption.
Did few tests yet but the numbers point to 153 kts TAS ate 8000ft (density altitude) with 31,5 lts/h (aprox 7,8 gal/h) - 65% power ( 21.5 map / 2450 rpm)
The engine sound changed a lot (due to fiddling in the injection) it is a bit rough in comparison to before, but the temps and pressures are ok with little variation between cylinders.
Keep you posted as new tests go and data is consolidated...
Happy already.
A note.... The fuel pump should have been changed in the 25 hours inspection by (warranty) but the shop that did stated that Service Bulletin No. 621B did not apply , they where mistaken it did and it almost cause a flight incident with problabe costs and injuries. I am claming for a refund on the fuel pump change costs.
Keep you posted!
Brazil
Others: RV9A
AND GARMIN AVIONICS
Old 07-03-2017, 09:00 AM
Chkaharyer99 Chkaharyer99 is offline
Alex,
Good job finding the problem and fixing it.
On another note, do you have any threads and pics detailing your RV flying experiences in Brazil?
Charlie
RV-8
Old 07-03-2017, 10:26 AM
Bavafa Bavafa is offline
Originally Posted by ALMARTON View Post
Folks,
Keep you posted!
Do you know which fuel pump you had and how it was missed by identifying it as "did not apply"? I just checked mine a couple of months ago and also did not apply to mine. There is three or more conditions need to match to apply.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 07-03-2017, 10:34 AM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Originally Posted by rv7charlie View Post
Bubblehead,
Run your numbers. If you're making 75% on a 180 HP Lyc and only burning 8.5 GPH, you just need a couple more events for it to be the 1st Lyc qualified for sainthood. That would be .377 BSFC. Extremely unlikely with a stock Lyc.
Charlie
My point is he can't be at best power at 14.6 gph 8000 ft density altitude. Maybe I was at 70% or 65% I don't know and it's not important. I was just going off the top of my head. But at cruise I expect to see about 8.5 gph not 14.6 and this is verified by monitoring what I put back into the tank.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 07-10-2017, 08:04 AM
Originally Posted by Chkaharyer99 View Post
Alex,
Thanks! I'm overall very happy with the results. After some more tests It seems that the results are consolidated. The plane is behaving as it should in respect to speed and fuel consumption now.
The only one oddity (to me) remaining is the fuel flow with the engine warming in idle (1000 rpm) indicates up to 4,5 gal/h (about 16 lts/h) but after warmed up it drops to 3 gal/h (about 9 lts/h) - That phenomena important to say happens now that is winter here (cold days about 59F / 15 C). Cruise consumption at 155 kts (TAS) is about 9 gal/h ! (confirmed) = 34 lts/h
Is that NORMAL? Do you verify that variation (idle warming flow vs idle hot flow) on your operations?
With regarding to my experiences here pics and movies I have this channel:
https://www.youtube.com/channel/UCCv...4DgLBUhGuenKIA
Alex,
Well its pretty easy to tell [IF[ you have visual access to the fuel pump, just print the bulletin and inspect it to answer the 4 questions written there in the SB to see if you pump applies. BUT in my case I asked to the repair shop (another one) to that was servicing my aircraft in 50 hours inspection to verify that. They did not and , even worse, when asked again they told me it was not applied to my pump. They mislead me.
Doing more testing and will post...
Nice flights! Blue Skies!
Brazil
Others: RV9A
AND GARMIN AVIONICS
Old 07-10-2017, 09:54 AM
Raymo's Avatar
Raymo Raymo is offline
Alex,
Your numbers jive with mine on a recent long cross-country (GA>TX>PA>GA). I was seeing 155TAS at 2450-2500 RPM, 20" MAP (60%) and 7.5 GPH fuel burn at 8500. At higher altitudes (10.5) I could get down to 7 GPH. I still have a lot of small jobs to further reduce drag and hoping to get the TAS up to 165. I may have to upgrade to the Superior cold air induction to get there (supposed to add 5-8 HP). Also need to perform the nozzle tuning checks as I think my #4 cylinder may be running rich compared to the others.
I took a bunch of screen shots of my Dynon screen while flying but they are on the USB stick in my plane. The one I like the most had a 30 KT tail wind with ground speed of 182 KTS (~210 MPH).
Ray
Old 07-11-2017, 07:30 AM
Originally Posted by Raymo View Post
Alex,
Ray, I'm getting happier and happier with my plane now! Its just a question now of adjust (improve) roll rate and fix a aileron buffet when full deflected and I declare it finished.
When you state those altitude numbers in you post it is Density Altitude or indicated (pressure altitude)?
Many thanks
Brazil
Others: RV9A
AND GARMIN AVIONICS
Old 07-11-2017, 08:46 AM
RV7A Flyer's Avatar
Are you talking about the aileron buffeting that occurs during an aileron roll at higher entry speed and full deflection?
If so, there's nothing to fix there...search the forums for threads on this phenomenon.
