  #11
Old 06-13-2016, 03:12 PM
Beagle's Avatar
Beagle Beagle is offline
Originally Posted by Bob Kuykendall View Post
If by "300Kmph" they mean 300kph, that's only 187 mph, meh.
If they mean 300 mph, well, that's a thing to give pause. I hope they've done their homework.
Back of the envelope physics tells me that max speed increases with the square root of the increase of the thrust so the 215hp spec makes me think think 300kph is correct.
-Bob "Beagle" Brents
RV-8 (Reserved: N808B sorta like "BOBB")
(Empennage: 95%)
(Wings: 60%)
?To invent an airplane is nothing. To build one is something. To fly is everything.? - Otto Lilienthal
https://www.facebook.com/fliegen.beagle
Dues Happily Paid 2019
Old 06-13-2016, 03:31 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
These are the same folks who created the 1000SHP Legend which cleaned up at the Air Venture Cup race. http://www.airventurecuprace.com/rac...-race-results/
215hp at 25,000 feet might get you close to 300mph TAS- if you can cool it.
I saw this airplane in the flesh about a month ago. Pretty cool project.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 06-13-2016, 04:26 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
Originally Posted by rv6ejguy View Post
...215hp at 25,000 feet might get you close to 300mph TAS- if you can cool it...
And if you can keep it from fluttering.
Old 06-14-2016, 09:38 AM
flyboykelly's Avatar
flyboykelly flyboykelly is offline
Bingo!!!!!
Flying as of 1-12-2016!!!!!
Old 06-14-2016, 12:12 PM
flyeyes's Avatar
flyeyes flyeyes is offline
On the other hand, if they really mean 300Kmph, that's very impressive.
I seem to recall the SR71 set a transcontinental speed record from LA to D.C. in roughly an hour which is pretty impressive.
At 300kmph the trip would take just under 28 seconds. In calm winds.
James Freeman
RV-8 flying
Old 08-01-2016, 07:43 AM
flynwx's Avatar
flynwx flynwx is offline
Talking Delta V = cube root(HP)
You are right about that. Speed increase is square root of thrust increase, so it is the cube root of HP increase. So, adding HP is an expensive way to increase speed. But, it can be impressive.
Scott "Stormy" Weathers
N7WX (reserved)
wings
Old 06-01-2017, 05:43 PM
foxhound57 foxhound57 is offline
Default Images of the RV8S
After full flight testing and receiving its COA from Transport Canada the aircraft was shipped to Hervey Bay Australia and is currently completing its CASA COA.
Old 06-01-2017, 05:48 PM
mburch's Avatar
mburch mburch is offline
Quite the inboard landing light location.
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 06-01-2017, 07:07 PM
F1R F1R is offline
Default Shreck just might have been right
Originally Posted by DaleB View Post
I normally try not to ask why someone would build a plane the way they did. In this case it's kind of tough. You still have a 160-kt two-seat tandem (apparently), it's just longer and heavier and has a bigger engine. More fuel for transoceanic flights? More room for a really tall person?
I'd love to hear what would motivate someone to go to the enormous time and expense it must have taken to build this. I'm sure there's an interesting story there.
To quote Shreck ... the hollywoood Shreck that is, " Do you suppose he might be trying to compensate for something?"
Maybe he flew Corsair's or Spitfires and missed not seeing the runway.
All in good humor. In reality that had to be a lot of work, time and money.
It should get above 20,000 Feet very quickly, as long as it does not freeze over a fuel tank vent.
Old 06-01-2017, 07:18 PM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
It looks like there are two baggage doors up front. The front cockpit looks to be normal sized so he did not stretch it to get more room in front. Vents on the side of the cowl sort of like Bonanzas. Throttle on wrong side but to each their own.
It would be great to get the builder on the forum to tell us about it.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
