Old 05-23-2017, 02:35 PM
Adrian Bonwitt Adrian Bonwitt is offline
Default Door Lock is broken..can you help?
Hi Everyone
The key was put in the barrel on the left hand main door and the barrel then broke away with the key in it. It was my passenger, not me, so am not sure how much force was applied.
Just trying to source the aftermarket part - any help would be appreciated. We have spoken to VANS and they suggested a post here.
Thankfully the handle still works, it is just the locking mechanism!
https://drive.google.com/open?id=0B2...jF5RFhKd0lkMkE
https://drive.google.com/file/d/0B2z...ew?usp=sharing
Old 05-23-2017, 03:19 PM
AviatorJ AviatorJ is offline
I can't help you with replacing with that exact lock, however I would suggest getting CompX Fort - MFW1058 Cam Locks. I have 3 of them on my project and it seems it would be impossible to break the key.
Justin
RV-10, N10JW
First Flight 2/14/2019
http://operationrv10.blogspot.com/
Old 05-23-2017, 07:37 PM
bhester's Avatar
bhester bhester is offline
Default Locksmith
I would bet that a local locksmith could replace that lock mechanism for you, it looks very much like a lot of tool box locks. You might be able to find it on ebay also.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 05-24-2017, 02:40 AM
Machsandy Machsandy is offline
I am co owner with Adrian, can anyone identify from the pictures who manufactured the aftermarket door handle, we could then try approaching them, thanks also for the suggestion re the locksmith, that may also work.
Old 05-24-2017, 03:16 AM
Jasonm Jasonm is offline
Who makes the lock and handle assembly? I can't tell from the pictures. I found some lower profile cylinders at an RV/Camping dealer. The thing to look for is the depth of the cylinder.
Jason McKay
RV-10
Old 05-24-2017, 03:32 AM
Default Looks kind of like...
Can't tell from the photos but it kind of looks like an assembly from aircraftspecialty.com...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 05-24-2017, 06:23 AM
I have sent an email to Aircraft Speciality, does this photo help with the identification?
https://www.dropbox.com/s/cm5z21ccp8...24691.jpg?dl=0
Last edited by Machsandy : 05-24-2017 at 06:25 AM. Reason: Link moved for clarity, I can't work out how to show pic rather than link
Old 05-24-2017, 07:09 AM
Aircraft Specialty Aircraft Specialty is offline
Our RV-10 Door lock is pictured here. It utilizes an offset lock which is captured by a receptacle in the existing RV-10 rack mounting hole.
The door lock pictured by Adrian in this thread almost looks like the AV8R designs door lock to me. But I am not certain on that. I think that they did a lock underneath the handle rather than integral to it. But, it is possible that this is a modification of one of their designs?
Steve Tschurwald- Aircraft Specialty LLC (Your source for Custom Parts for Experimental Aircraft), AS FLIGHTLINES (Joint Venture with TS Flightlines)
aircraftspecialty@gmail.com
www.aircraftspecialty.com
www.asflightlines.com
Old 05-24-2017, 02:51 PM
xavierm xavierm is offline
It looks like a cabinet lock that can be found in your aviation isle at your local hardware store.
_____________
Xavier
RV-7 build in progress
www.theaviatorx.com
"Genius is persistence in disguise"
Old 05-24-2017, 04:22 PM
unqualified unfluencer
Thumbs up Manufacturer looking for OP to contact him....
I got this email today from Henkjan 'at' zme 'dot' nl
"I see on VAF that a doorlock is broken, I made a few sets of those locks years ago.
I still have some spare locks on the shelf, no charge, just for shipping costs……
You might remember me, I bought the RV6 of Alex de Dominicis (also years ago)
Can you get me in touch with Adrian Bonwitt, I’ll ship him the locks."
There you go <g>. Problem solved. Great community!
Doug Reeves (your host)
