Old 05-24-2017, 11:23 AM
BruceMe's Avatar
BruceMe BruceMe is offline
Default Best master switch saver?
I'm handy with electronics and I'm sick of killing my battery because I forget to turn off the master... I know, this is a "millenial problem" like FADEC and glass panels. But it's getting old and a $5 circuit can fix it.
Requirements:
  • Must not accidentally turn off on final after a long flight (simple timer)
  • Must have very-very low current when off (<1pA)
  • Be cheap and reliable
  • Avoid failing-off... ie if it dies, stay on
Design
Use a micro-controller connected to a sensitive vibration detector that resets a one-hour timer. After one hour of near-total-non-movement or 2 seconds of holding the power-switch; then collapse the power supply and de-energy the master solenoid. An LED would indicate "On" when solid, blink when in some state of turning-off.
It would be installed in place of the master switch on an aircraft and could be built using a single LED momentary switch.
Components;
I'll post an updates as I'm building and when it's done.
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
Old 05-24-2017, 11:37 AM
krw5927 krw5927 is offline
I'm imagining a simple piezo buzzer mounted out of sight behind the panel, and powered by the master bus through the normally-closed side of a standard oil pressure switch.
Same principle as the "Low Oil Pressure" annunciator light in common use. A light can be easy to miss. An annoyingly loud buzzing noise, not so much.
Kurt W.
RV9A
FLYING!!!
Old 05-24-2017, 11:47 AM
FasGlas's Avatar
FasGlas FasGlas is offline
Or you could just put a pressure switch under your seat (like cars have for seatbelts), connect it to the master power and a piezo horn. As soon as to get out and the master is still on the horn blows... I'm not sure I would trust the only source for aircraft power on a handful of sensitive electronic parts. IMHO.
Old 05-24-2017, 11:56 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default strobes
I always leave my strobes on - can't miss those when I forget the master.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 05-24-2017, 11:58 AM
tomkk's Avatar
tomkk tomkk is offline
Same here ...
Tom
Port Orange, Fl
EAA #51411
Old 05-24-2017, 12:06 PM
BruceMe's Avatar
Default Thanks
Buzzer is simpler and I've had one like that, I've had this idea for a long time. And it's never after a flight that I leave the master on... it's after working on it.
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
Old 05-24-2017, 12:39 PM
Raymo's Avatar
Raymo Raymo is offline
My flap motor often reminds me of two things after shutting the engine down
Ray
Old 05-24-2017, 12:40 PM
jfrank71 jfrank71 is offline
Default +1 strobes on all the time
Never thought I would leave my master switch on. After 20+ years of flying, it finally happened. So now I fall into the group of people that leave the strobes on all the time. When I get out, strobes will be a gentle reminder that I left the master on. Not sure about the master switch on a timer plan. Sounds like a potential point of failure.
+1 strobes
Frank Leone
RV-10 Purchased
RV-12 Under Construction by my kids, wife & me
Donated 8/2018
Old 05-24-2017, 01:07 PM
tomkk's Avatar
Originally Posted by tomkk View Post
Same here ...
... although I must admit, the one time I left the Master on I had turned the strobes off to work on the plane.
Tom
Port Orange, Fl
EAA #51411
Old 05-24-2017, 01:13 PM
rv8ch's Avatar
Default car keys
If working on the plane, tape your car keys to the master switch, or hang them on the switch if it's a toggle switch. Can't leave without your car keys!
Mickey Coggins
http://rv8.ch
"Hello, world!"
