05-23-2017, 08:46 PM
Safe margin of tread wear
Been spending most of my time shooting landings. Have tire wear to show for it.
Not sure how far to run these out before they become subseptible to puncture. Flying off good pavement but there is always the chance of sharp rocks, etc.
Do I wait until cord is showing?  Haven't done that since high school.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2020(my reminder ).
05-23-2017, 08:52 PM
Senior Curmudgeon
Dismount and flip over, remount and you are good for lots more landing pracitce.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
05-23-2017, 08:53 PM
Well, I would have flipped them a few hours back, to even out the wear. Now,
I'm not sure. Can't tell how thin the area is with no tread.
05-23-2017, 09:11 PM
Ah, but how much more?
That's my concern. No wear indicators.
Blain
R-22 sold.
N82 Sierra Tango
05-23-2017, 09:16 PM
If both tires are wearing the same, which from what I can see is on the inside, I'd pull them both and remount to where the less tread side is on the outside. Still plenty of life left in that direction. Otherwise, I'd be ready to order new rubber.
05-23-2017, 11:48 PM
Senior Curmudgeon
Check with Vlad......he would consider these brand new
Mike Starkey
VAF 909
Rv-10, N210LM.
05-24-2017, 04:09 AM
Tires
Good Year says when the tread grooves are no longer visible . The first set I took off had minimal tread left . I cut the tire on the band saw so I could see and measure how much rubber was left . My observation was Good Years recommendation is a good rule of thumb .
A set of tires cost about the same as a tank of fuel , puts it in perspective . Don't run out of either .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
05-24-2017, 05:45 AM
Most RV tires wear on the outboard side. I wait until the grooves are just about gone, then flip them and basically have a new set of tread to wear on. When that side is just about through the tread, I change them. The retreads have more rubber after the grooves are gone, so I wait until hey are completely gone on the retreads.
Jesse Saint
05-24-2017, 06:27 AM
Honestly, stuff like this amazes me that it would even be posted, that you would even consider risking so much for so little is beyond me.
JUST REPLACE THE FREAKIN TIRES!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
05-24-2017, 06:35 AM
I have to mostly agree with Walt on this. Remember that "6-ply rating" does NOT mean the tire has 6 plys. I recommend replacing the tires when the tread is gone.
Rotate the tires when the tread gets low (still visible) on one side. When the tread is low on the second side, replace them.
You REALLY don't want to deal with a blow-out on landing.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
