05-23-2017, 09:47 PM
Braided SS brake lines
What are Yall recommending for braided SS brake lines? Both interior petal lines and lines going down gear legs. Do you have to have them custom made or are there lines already made up that you can buy?
Allen Blackwell
Tylertown, MS
Very slow build RV7A
05-23-2017, 10:29 PM
I bought mine from Bonaco. They used to advertise here, don't see them at the moment. They were heavy because they didn't use alum fittings.
I suggest you contact Tom at
tsflightlines.com
He knows what you need. Great product and service!
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
05-24-2017, 12:56 AM
Braided brakelines
I fabricated my own quite easily after visiting a hydrolics repair shop and being shown how to cut to length and fix the ends. My end fittings are steel. ( heavier)
This suited me as I could tailor make them in situ.
I find this a more satisfactory solution than making aluminium lines supplied by Vans. My previous plane needed aluminium lines replaced due cracking.
Jeff Rowlands
05-24-2017, 05:39 AM
Edelbrock/Russell Motorcycle Brake Lines
I used the AN3 Edelbrock/Russell Motorcycle Brake Lines. Amazon carries them in various lengths and with various angles on the ends. Jegs and Summit Racing also carry them. The braid is wrapped with clear vinyl to prevent stones from damaging the SS overbraid. Typical Russell Brake Line
(2020 dues paid)
05-24-2017, 09:19 AM
John,
Do you know if these lines are pressure tested?
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
05-24-2017, 09:34 AM
Braided brake lines
I installed Beringer brakes. The included lines are all braided. Nice part is it allowed one piece lines from the last connection inside to the wheels. TS Flightlines makes them too.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
05-24-2017, 09:53 AM
I highly recommend Tom Swerigen from TS Flightlines. He makes great products and offers exceptional customer service. He is an advertiser (i think).
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
05-24-2017, 09:58 AM
+3 for TS Flightlines. You'll never have to change them again.
Ray
05-24-2017, 12:06 PM
I don't think they're tested individually, but they meet U.S. Dept. of Transportation FMVSS-571.106 requirements of 5,000 PSI burst strength and 150 pressure cycles, at 295 degrees Fahrenheit with no leakage. I figure if they're good enough for a Harley, they're good enough for my airplane
(2020 dues paid)
05-25-2017, 06:13 AM
True---but there were very few OE automotive companies that used teflon for brake hose at the calipers. ABS pump hoses are a different story. In a previous 'life', we built DOT brake hoses. Really only one real supplier of OE styled hose and fittings, not adapted hose ends used with -3 teflon, like most aftermarket companies, like Earls, Russell, Goodridge.
I agree with the pressures. The Lab tests use the chart that you showed, but generally we tested to 3000 psi.
Tom
Ridgeland, SC
