I think it depends on your plan for your wiring. Using bus bars is a good approach if you are using circuit breakers. If you are using fuses then the fuse block provides the power distribution to the protection devices (fuses). To me terminal blocks are best used for other functions instead of this type of power distribution. An example might be a circuit where you need power to several locations on the same circuit, say maybe interior lighting as an example. Terminal blocks could also be used instead of a connector in certain cases to join wires. I'm not really a fan of terminal blocks, but there may be some use for them in certain applications.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
