Old 05-22-2017, 01:01 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Beeswax is also very good to use when tapping aluminum.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-22-2017, 01:08 PM
mturnerb mturnerb is offline
Originally Posted by Bill Boyd View Post
(besides tapping the plates very gingerly to loosen them some, which I no longer do): Wax toilet bowl ring for thread lube. One ring will do about 6.02x10^23 screws. Valve lapping compound on the tip of the Phillips bit - gives greatly improved grip and prevents cam-out. Quality Wiha screwdrivers. Pay the Germans and buy once-cry once.
EZ-Outs for when the above fails. If you don;t chase a tap through your #6's, I believe it's only a matter of time under the best of conditions...
A mole of screws??? What's the atomic weight of a screw?
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
Old 05-22-2017, 01:57 PM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
This helpful hint first published in The Experimenter by Avogadro
He considered it to be the normal solution.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
Old 05-22-2017, 01:59 PM
Bill Boyd's Avatar
That's none of your beeswax
Bill Boyd
Old 05-22-2017, 02:54 PM
Arvey Fleur's Avatar
Arvey Fleur Arvey Fleur is offline
Wink Ribbed for your pleasure
I always make sure I have ribs on my tip when screwing. I do not use lube, I just put them in there. No sweet-talk or anything like that, just go for it.
https://www.amazon.com/Bosch-46005-R.../dp/B0065ID2BU
The lil ribs on the tips hold the screw tightly. This also helps in tight quarters and unusual positions if the driver is a little out of alignment with the screw. As for the shaft, the threads do get roughed up by the nutplate, but I figure that is how it is supposed to be?
DanR
RV8
"Life seems so much simpler when you're fixing things." - Anakin Skywalker
Dues Paid 2020
Old 05-22-2017, 03:08 PM
Paul K Paul K is offline
If you think it's an issue of dirt, paint, or other FOD, I cut a slit length wise in the threades with a dremmel. The slot cleanes out any materials without cutting new threads or making the "hole sloppy" just use the screw as a chase and then replace it with a new fresh screw.
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
Old 05-22-2017, 03:20 PM
BillL BillL is offline
+1 But lube allows return performance, less trauma.
I seldom (almost never) have a driver slip now with the ribbed, replaceable tips.
Bill
RV-7
Lord Kelvin:
Old 05-22-2017, 03:28 PM
wirejock's Avatar
wirejock wirejock is offline
Default Tap
Boelube for sure but I actually run a tap in three turns. It leaves plenty of tension. Downside is the time involved. When I have a few extra minutes but don't want to start a new step, I tap nutplates.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 05-22-2017, 03:30 PM
n567vb n567vb is offline
Originally Posted by Jasonm View Post
I have started replacing all #8 phillips head screws with these.
https://www.microfasteners.com/fcmxs...stainless.html
Doing the same for #6 screws.
These strip even more than the phillips. Ask me how I know. I did both wing tips with these and i get a few stripping every time I remove the tips. I've been switching back to Phillips as these strip.
Vince
RV-7
Old 05-22-2017, 05:45 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
1) Torx might seem like they strip easy, but are you sure you are using the correct sized bit? Because they work for a while with the wrong bit, and then strip. Also, people often mix Torx and Allen tip heads all the time. Again, they mostly work but will strip eventually.
FYI, Phillips head screws are designed to strip. They were first created so machines could drive screws, and have the head strip before the threads did.
2) For sure tap the nut plates. I think they are using the same tap to make them, that they used 50 years ago, and it is getting small.
3) Boelube also helps a lot.
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
