Old 05-15-2017, 01:35 PM
larrynew's Avatar
larrynew larrynew is online now
Smile Anti Splat Nose Wheel Bearing Mod - Results or Regrets
I'm considering doing the Anti Splat Nose Wheel Bearing Mod during my second Condition Inspection. Boy, how time flies . Any results or regrets with the modification you'd like to share?
Larry New
RV-7A - Built, flying 900+ hrs
RV-10 - Built, flying 2.9 hrs
??? - RV-12, Subsonex
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 05-15-2017, 02:12 PM
Omega232Devils's Avatar
Omega232Devils Omega232Devils is offline
Default No regrets
Larry,
Do the MOD, you won't be disappointed.
1) Your plane will require less power to taxi, which shows you the drag the original setup has.
2) Having 1 less set of bearings to grease is always a bonus.
3) The biggest advantage that comes to mind is a tire change in the field, meaning you do not have to worry about dirt getting in the grease. (Ask me how I know!)
Allen is top notch to deal with. I have NO regrets at all.
Dan
Dan Thompson
RV-6A - N426JM - 180hp / C.S. / dual PMags
NC26 - Long Island Airpark, NC
Old 05-15-2017, 02:33 PM
rvator9a rvator9a is offline
I had mine done about ten hours ago after my nose wheel shimmied so bad it shook the wheel pant off. I also had them mount a new tube and tire. I had them perform the tire "trueing" but when the tire was mounted it still had a notable amount of radial runout.
The difference between before and after was dramatic. It does steer and handle better on the ground, but the big difference is on landing, no more vibration or shuddering when I let the nose down.
It was well worth the minimal cost, and Alan made the whole process easy.My .02
Bob Collins (the other Bob Collins)
Old 05-15-2017, 02:39 PM
n468ac's Avatar
n468ac n468ac is offline
before and after was so dramatic! Well worth the money!
Really thinking hard about doing the mains at annual.
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Old 05-15-2017, 02:44 PM
Bugsy's Avatar
Bugsy Bugsy is offline
My input mirrors what other have said. I was so happy that I had the main wheels done as well.
The nose wheel mod is very noticeable
Paul
Paul 'Bugsy' Gardetto, Col, USAF (ret)
Milwaukee, Wisconsin (Timmerman Field)
N377KG - Flying (250 hrs)
RV-7A, Aerosport O-360, WW200RV
Advanced Flight 5400
Avidyne IFD440
Paint by planeschemer.com
Old 05-15-2017, 03:02 PM
rvbuilder2002's Avatar
The common cause of that is lateral (steering) shimmy.
The Mod that Alan does will do nothing to prevent that.
Only correctly adjusting the steering breakout force will......
Scott McDaniels
Hubbard, Oregon
Old 05-15-2017, 03:10 PM
airguy's Avatar
airguy airguy is offline
Paul
I'm very happy with the nose wheel mod, I didn't realize it was an option for the mains as well.
Old 05-15-2017, 03:14 PM
DSmith DSmith is offline
I really like the mod. The aircraft rolls so easy that you will use more brake when you land on a paved runway.
Danny - PCB, FL
RV-7A, TMX IOF-360, WW 200RV
GNS480, SL40, GRT EIS/Two HWS, TT
Old 05-15-2017, 04:13 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default Do it
Paul
I did the same. And as a bonus, there are no bearings to grease.
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
Old 05-15-2017, 07:36 PM
bret's Avatar
bret bret is offline
Ditto all above.
