Go Back   VAF Forums > Model Specific > RV-9/9A
  #11
Old 05-09-2017, 03:43 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Rivet removal tool
Gents,
I posted this years ago but if you are building an RV you will be removing rivets. On my website you will find the info under builder tips.
http://www.experimentalaero.com/SARRT.htm
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 05-09-2017, 04:05 PM
KRviator's Avatar
KRviator KRviator is offline
While the shop heads may be a little thin, I think the majority, if not all of them, would actually be okay from a structural standpoint.
Alcoa (Think it was them) did a bunch of tests way-back-when to determine how much strength was lost from poorly and mis-set driven rivets, where it was determined even what we would view as shockingly bad rivets, rivets with cracked heads, etc, were still within 5% of the strongest properly-set rivet. Can't remember where I read it, but I'll try to find it.
In my mind, you're likely to do more damage drilling out a long line of rivets and replacing all of them than leaving them as-is.
EDIT: Haven't found the article yet, but multiple quotes from it:
Originally Posted by Alcoa Aluminum Rivet Book, dated 1984
"The standards to which driven rivets should conform are frequently uncertain. In addition to dimensions and perfection of shape, inspection is concerned with whether the drive head is coaxial with the shank (not “clinched”) and whether there is excessive cracking of the heads. It has been determined that even badly cracked heads are satisfactory from the standpoint of static strength, fatigue strength and resistance to corrosion. (Poorly set and cracked) rivet heads were tested in tension to determine how well formed a head has to be in order to develop full strength. The tensile strengths of all the rivets were within five per cent of the strongest. The test indicated that minor deviations from the theoretically desired shape of head are not cause for concern or replacement. The second rivet that is driven in any one hole is likely to be more defective than the first because the hole is enlarged and rivet will be more likely to buckle and form an imperfect head.
Tests have shown that very small rivet heads are sufficient to develop the strength of the rivet shank, even when the rivets are subject to a straight tensile pull….where a large head is not needed for appearance, smaller sizes of drive head should be used to decrease the required driving pressures.
And a quote from another VAF'er regarding poorly-set rivets:
Originally Posted by Michael Burbidge
Here's the advice I received from Vans technical support when I asked them whether I should go to the next size rivet or not.
"Our advice is to never drill out a rivet unless you have to take the assembly apart. No matter how ugly it is, it probably has 90% the strength of a perfect rivet."
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 05-10-2017, 10:04 AM
Neal Trombley Neal Trombley is offline
Vans reply
The only way to determine if these are acceptable is to take some measurements. See link below and compare the specifications to what you have.
https://www.vansaircraft.com/public/Specs.htm#TABLE III
I measured and removed those out of spec
Thanks to all...
I now have my masters in rivet removal
Neal Trombley
SW Florida
EAA 66
N517NC ( reserved)
Dues Paid
NOV 2016
July 2017
Dec 2017
Old 05-10-2017, 01:21 PM
az_gila's Avatar
az_gila az_gila is offline
Question
Originally Posted by Neal Trombley View Post
Vans reply
Thanks to all...
Good move
Out of interest, what approx. percentage of the short rivets were out of spec?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-10-2017, 02:02 PM
Originally Posted by az_gila View Post
Good move
30% not too bad
Neal Trombley
SW Florida
EAA 66
N517NC ( reserved)
Dues Paid
NOV 2016
July 2017
Dec 2017
Old 05-11-2017, 12:40 PM
mbishop mbishop is offline
I saw some WWII planes last year at OshKosh with worse rivets.
Working on the fuse (RV-10).
Old 05-11-2017, 01:25 PM
Mel's Avatar
Mel Mel is offline
But you must consider that WWII fighters were built to last only a couple hundred hours.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
