Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
  #271
Old 12-21-2016, 03:43 PM
catmandu's Avatar
catmandu catmandu is offline
Originally Posted by b1driver View Post
Awesome and simple all-in-one unit...but no AHRS. What USB option are people purchasing to add the AHRS capability?
RY835AI off of eBay is the go to GPS / AHRS unit for a lot of Stratux builders. But the AHRS capability may never come about (I have been waiting for it for a year), it apparently is a very technically challenging capability. There is, however, a GPS attitude solution in beta testing that looks promising, so buying that chip would give you something, maybe more down the road.
Mike C.
Sierra Nevada
RV-6A bought flying
Old 12-22-2016, 10:53 AM
DSmith DSmith is offline
FlightBox has the AHRS working and for sale - Beta at this time.
Danny - PCB, FL
RV-7A, TMX IOF-360, WW 200RV
GNS480, SL40, GRT EIS/Two HWS, TT
Old 02-17-2017, 01:52 PM
Snowflake's Avatar
Default New Stratux software v1.2r1
Available on the Stratux github:
https://github.com/cyoung/stratux/releases/tag/v1.2r1
GPS-based AHRS. Serial output. Bugfixes.
Changes since v1.0r1:
Serial output for CP2102 with a programmed EEPROM.
"Developer mode" webui menu.
UAT statistics display.
Change green LED meaning on RPi - was: filesystem write, now: Stratux running.
Minor changes since v1.1b1:
Command line utilities managing ssid/Wi-Fi settings.
Reduced GDL90 traffic report size to 35 targets per message.
Fan control PWM script improvements.
Rob Prior
Old 04-16-2017, 12:45 PM
carlrai's Avatar
carlrai carlrai is offline
Default Building dual band Stratux from kit on Amazon
Easy peasy.
One thing isn't clear though. Neither of the nano receivers provided have any indication of the frequency they are tuned for. Can't tell which one should be connected the appropriate antenna.
Or am I missing something?
Powered up unit and viewed output through wireless connection on my laptop, all sitting on the dining room table. All seems good on 1090 but no indication of signal reception on 978.
When powered up, one of the receivers has a blue LED illuminated, the other is is white with a green caste. Don't know if this means anything. No mention of how to distinguish in the instructions. Am I missing something?
Hope someone has a clue to this. All help appreciated.
Carl Raichle
Lutz, FL
RV-9A N194CR
RV-14A Under construction
Based at KZPH
AA4SR
Old 04-16-2017, 01:58 PM
jwyatt jwyatt is offline
Check on either side of the metal USB portion of the SDR, mine were labeled in sharpie there.
Failing that, you can boot up with only one plugged in, and at the command prompt type:
Code:
service stratux stop
rtl_eeprom -d 0
If your SDRs were purchased pre-programmed, the response to the above command should include a line marked "serial number," and the serial number strong should contain the number either 978 or 1090.
Joshua Wyatt | Goodhue, Minn.
RV-9A N627DW @ KRGK - Flying since 2012
AFS 4500s | Stratux | SDS EM-5
rv9a.pacificrimsound.com
Old 04-16-2017, 04:02 PM
carlrai's Avatar
Default Nope
Code:
rtl_eeprom -d 0
No id of any kind. No monitor either. Can this be done when connected wirelessly to laptop?
Carl Raichle
Lutz, FL
RV-9A N194CR
Based at KZPH
AA4SR
Old 04-16-2017, 05:01 PM
DaleB's Avatar
DaleB DaleB is offline
Yes, and you can configure the two radios for specific bands. You will need something like PuTTY or a similar SSH program on your laptop (http://www.chiark.greenend.org.uk/~s.../download.html) to connect to the Raspberry Pi. Then you follow these directions.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 05-03-2017, 06:24 AM
JimS JimS is offline
Just bought the DMurray antennas for my stratux. Is the NooElec dongle that the old antenna plugged into not used with these antennas. Looks like they plug right into the case.or is my raspberry an older version that won't work with these antennas?
JimS
Built and flying a Kitfox IV / 912
Bought and flying an RV-6 / 0-320 FP slider
Built and maintaining a 1800' grass runway
LIVING THE DREAM!!!
Old 05-03-2017, 07:20 AM
lr172 lr172 is offline
Antennas should have SMC connectors and they plug into your SDRs (like the Nooelec) They do not get plugged into the Pi. Did your antennas also come with small square devices that have an SMC plus a USB connector? If so, those are new SDRs that replace the Nooelec.
Larry
Old 05-03-2017, 07:23 AM
If your antennas are tuned for individual frequencies, like the Dmurray units, you'll want to take this step. Otherwise stratux will assign the frequency and you'll only have a 50/50 shot that they match the antenna.
Larry
