05-01-2017, 07:19 PM
Updated/fixed? Bent elevator spar
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
05-01-2017, 07:27 PM
A good opportunity to "counter-flute"! Counter-fluting may not be the best method but that looks like a quick and simple fix.
Claudio Scremin
N221Z RV8A Maine 600+ hrs
05-01-2017, 08:11 PM
I'd try to bend it back into place, but unless you can get rid of any, and I mean any out-of-planeness, the spar probably should be replaced. Or it can perhaps be doubled there by adding a doubler.
Either way, this is a critical structural issue and you should contact Van's support.
The aspect that makes it important is that when the spar cap is loaded in bending, the flange is in compression and any deviation from straightness is a potential location for local buckling. Local buckling of a spar cap is a failure mode.
Dave
RV-3B, now on the fuselage
05-01-2017, 08:22 PM
Looks fixable from photo
From the photo it looks like it could be bent back into position without issue. However as others have mentioned, get feedback from Vans.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero- HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
05-01-2017, 08:23 PM
Spar
The aspect that makes it important is that when th spar cap is loaded in bending, the flange is in compression and any deviation from straightness is a potential location for local buckling. Local buckling of a spar cap is a failure mode.
Dave
I wouldn't even consider it. Replace it. It's not installed yet so a swap is easy.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
05-01-2017, 09:28 PM
Thanks for the replies guys, I'm pretty keen on replacing it myself even though I'm torqued about it. I don't mind paying the $20 bucks to Van's it's the $31 dollars to UPS that I'm not happy about. This will be the third time I will have to ship a spar and it's getting old, I wish my mistakes were on tiny doublers! haha I'm also curious if Van's will say to add a doubler as one of you mentioned, I have seen them do that before when I thought they wouldn't. I'll keep you posted.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
05-02-2017, 07:26 AM
Jereme--
Take a deep breath. Relax. I assure you that it wont be the first pieces you'll have to replace. Everyone does it at least once, some of us more than that
Tom
Ridgeland, SC
05-02-2017, 08:24 AM
Shipping
Originally Posted by jcarne
I don't mind paying the $20 bucks to Van's it's the $31 dollars to UPS that I'm not happy about...
Order snail mail. There's always something to do while you wait.
Larry Larson
Estes Park, CO
Disclaimer
05-02-2017, 09:31 AM
Originally Posted by TS Flightlines
Jereme--
Tom
I stopped looking at my pile of mistakes with shame and started looking at them as lab experiments that led to the proper outcome. I will be ordering angle today that I need more of. I am sure that the last thing I ever do on this build, before flying, will be waiting for USPS to deliver a replacement for something I goofed up on.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
05-02-2017, 10:25 AM
Try bending it back with hand seamers, avoiding the edges of the dimpled hole. If you can get it close, take your squeezers and redimple the hole. The dimple die will reform the area around the hole. As an experienced sheet metal guy, I would have that fixed in about two minutes. If you mess it up further trying to fix it, you will have learned a bit more and then you can order a new part.
This really isn't that bad and is easily fixable in my opinion.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
