Old 04-30-2017, 04:14 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Mag check at altitude-EGT increase?
I decided to perform a mag check at altitude yesterday. I have an IO-360 with a CS prop. I was crusing at 8.5K a little ROP when I tested the mags.
The mags were fine but what I noticed was the EGT's were increasing. This was true with either the right or the left mag and I repleated this twice to confirm the reading. When I did switch mags I only let it run with one mag off for about 5 seconds. But the increase in EGT's was noticable.
I am trying to understand why the EGT's would increase with a less than efficient combustion.
Any ideas?
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 04-30-2017, 04:31 PM
kkmarshall kkmarshall is offline
Default Normal
EGT's will rise as less efficient combustion has more burning of fuel still going on when the exhaust valve opens.
Keith
Keith
329DR RV10-bought flying
Continually upgrading/tweaking
Old 04-30-2017, 04:36 PM
scard's Avatar
scard scard is offline
Nothing special here. You'll see it at runup as well.
Scott Card
CMW E-Lift
Old 04-30-2017, 04:44 PM
Pmerems's Avatar
Default Less unburned fuel?
My first thought was that less efficient combustion would lead to a richer mixture. Since I was already ROP I would have thought the EGT's would drop a bit.
zilik's Avatar
zilik zilik is offline
VAF Moderator
Originally Posted by Pmerems View Post
I
Any ideas?
You answered your own question. With one mag off the combustion is less efficient allowing the still burning mixture out the exhaust. This is perfectly normal.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
Old 04-30-2017, 08:08 PM
Aggie78 Aggie78 is offline
Default Most all you'll need to know...
Found here:
https://www.cirruspilots.org/cfs-fil...10_2D00_09.pdf
Great article on mag checks by Mike Busch.
Enjoy that mag check even more fully now!
Rob Schroer
RV-7/N75WV
YIO-360-M1B
New Braunfels, Texas (KBAZ)
VAF Monthly Donor
Old 04-30-2017, 08:20 PM
bhester's Avatar
bhester bhester is online now
Thumbs up Yep
That is one of the best indication when you lose a mag in flight, rapid rise in EGT.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 05-01-2017, 07:55 AM
Pmerems's Avatar
Default Mike Busch-He's the man
Great info. Thanks for locating it.
Originally Posted by Aggie78 View Post
Found here:
Old 05-01-2017, 07:58 AM
lr172 lr172 is offline
Ignition timing, in combination with other factors, determines where peak cylinder pressure occurs relative to crank rotation and EGT will change as this point moves. Optimum PCP positions will leave more heat in the cylinder (heat converts to work moving the piston) and less optimum will lose more of that heat to the exhaust (heat is wasted).
Timing in a twin plug engine is based on the combination of two spark events. When you shut down one mag, you are retarding your effective timing and therefore the position of peak cyl press. This causes your EGT to shift as a result.
Larry
