Old 04-30-2017, 03:48 PM
ArVeeNiner's Avatar
Default Help! My ignition leads don't fit my new UREM37BY Plugs!
Hi all
A friend of mine sold me a brand new set of UREM37BY plugs to replace my URHM40E plugs. I got them all checked out and installed but when I went to install my ignition leads, they don't fit. The insulatorS of the old plugs sit deeper in the shell than the 37 BYs.
37BY
40E
How do I make this work? What parts do I need?
So much for this being an easy swap.
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
Old 04-30-2017, 07:08 PM
longline longline is offline
Default As far as I know
there are no parts to adapt from the style harness you have to the style plug you have installed. Most likely you will have to replace the plugs you bought with the appropriate plugs. As you discovered, the letters preceding the numbers really do matter.
Old 04-30-2017, 07:34 PM
It gets worse. The nut has the wrong size threads, too, for that plug. REM and RHM cannot be interchanged, unless you re-do the harness.
Old 04-30-2017, 07:37 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
I'd be interested in your new 37BY plugs if you can't use them.
Kelly PM sent.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 04-30-2017, 07:38 PM
ArVeeNiner's Avatar
I guess the great deal that I got from my friend on the plugs wasn't such a good deal after all!
I already put my old plugs back in and stay tuned for my classified ad for these plugs.
Kelly Johnson
San Jose, CA
RV-9A
