04-30-2017, 03:34 PM
Black Streak under Wing
Today I noticed some black streaks running back from the spar area under the right wing on my 6A. It looks like classic aluminum fretting residue, but not sure what could be rubbing in there. It is coming from the seam where the fuel tank attaches and goes backwards. It is w
Tonight I will pull the fairing strip at the wing root and see if I can spot anything with a flashlight and magnet.
Any ideas what this could be from or common issues like this? I would assume a simple fuel leak would leave blue streaking and not black. Though I suppose fuel could be the way the black is working out. This is a new issue at 300 hours.
[IMG]  [/IMG]
Thanks for any thoughts or ideas on this.
Larry
04-30-2017, 04:20 PM
My Money Is On ....
A very slow fuel leak. Speaking from experience, waiting for some steady, warm weather to get at mine.
Terry, CFI
RV9A N323TP
04-30-2017, 04:46 PM
Proseal deterioration due to fuel leak?
Just another guess. Hope not, but I have seen Proseal soften and get rather gummy in some cases.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero- HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
05-01-2017, 07:43 AM
Thanks for the input here. My first thought was fuel as well, but struggled to understand how it turned black. I suppose the leak could be pretty slight and it is picking up junk as it flows around before exiting.
I'll post an update once I can confirm what is happening.
Larry
05-01-2017, 07:53 AM
That's what my fuel leak looked like until it got bad enough that the volume of fuel outweighed the volume of dirt particles carried by it... :/
Rob Prior
05-01-2017, 08:00 AM
Could be just a mix of oil,fretting and brake dust. Add some dirt/rain and you get something like these swirls.
05-01-2017, 08:08 AM
That's what I was thinking this morning. Good to know your experience to help me confirm it.
Larry
05-01-2017, 08:15 AM
Thanks Vlad. that's a good thought. I haven't flown in the rain recently and can't think of how I would have gotten water in there within the last few flights.
Larry
05-01-2017, 11:07 AM
Larry
Many receipts from cash registers will turn color when exposed to gasoline or avgas. Tape such a receipt under the wing in the area of the suspect leak - if it turned color, that's a reasonable confirmation of a fuel leak and if it did not then the cause is likely something else.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
05-01-2017, 01:09 PM
Larry
That trail is being formed by liquid. If you have not flown in the rain, nor washed the plane recently then you must have a fuel leak.
