AT&T Changed Their Support As Of 1/1/2017
Larry,
I installed a Verizon MiFi6620L hot spot, an Insteon hub, an Insteon switch, and an old Ethernet bridge I had on hand. My cost is $10.00 a month with a Verizon prepaid plan, but it's worth it not to drive 40 miles round trip just to plug in the preheater. I am using the Insteon app on my iPad to set the schedule, turn the preheater on and off, and check the status of Insteon switch.
Hope this helps.
Roger Grahl
Lac du Flambeau, WI
RV-9A Slider
Empennage - Completed
Wings - Completed
Fuselage - Completed
Finish Kit - Under Construction
VAF donation through October 2020
