Old 04-27-2017, 06:40 PM
SgtZim SgtZim is offline
Default Landing gear - tightening the o/b nuts
Anyone have a neat trick or a source for something like a very short 9/16 socket to drive those outboard bracket nuts when installing the gear?
Kinda trying to avoid removing a bunch of nuts inside the tower when I go to put the gear on and they do interfere with my normal socket.
Snap-on has an interesting universal access socket with a ujoint built in for $45 but I can't even tell if it would work here.
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
Old 04-28-2017, 10:46 AM
N258RE N258RE is offline
RV-8
flying
Old 04-28-2017, 02:40 PM
Thanks RE That looks handy.
I found some long wobble extensions for my sockets at Harbor Freight today. I think I can get the job done now - also ground about 3/8" off of my 9/16" socket. Still going to need to remove several screws and bolts in the towers to get the nuts torqued.
I'll post some pictures on my FB pages when I put the gear legs on.
RV-8 slow build
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Old 04-28-2017, 03:08 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
This is what I used. Still tricky, but doable.
Old 04-28-2017, 06:47 PM
That's it - the tool I had in mind. I think I'll order one in case my cut down Craftsman doesn't work.
Thanks!
RV-8 slow build
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Old 04-28-2017, 08:21 PM
DanH's Avatar
DanH DanH is offline
Got some AN3's in the way, right? Just go ahead and move them now. None of it will be easier at the first annual and after.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-01-2017, 03:56 PM
Will definitely plan any wiring pass throughs to not get in the way. Need to find a friend with tiny hands.
RV-8 slow build
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Old 05-03-2017, 01:17 PM
FlyGood FlyGood is offline
Default Landing Gear Bolt Orientation Option
Food for thought: I put my outboard bolts in from the top, and then inserted a steel bar in the bottom cavity of the gear tower, between the inboard flange and the bolt heads. This bar prevents the bolt heads from turning when the nuts are torqued. The bar is held in place by a little RTV and the interference fit.
Now the washers and nuts are under the fuselage, so the fairing in that area will have to be made a little deeper, or with a little hump in them to clear the nuts. I plan to cut holes in the fairings to access the nuts with the socket. Initial torquing was a one-person, easy job with a 'standard' socket wrench.
Ken Cockrell
RV-8 Fuselage Slow-Build In-work; on gear
Tail Kit complete
Wings In-work
N247TM Reserved
