Originally Posted by rv8gibbo
No worries Rob thanks for your help I will wait until I have the canopy cut and fairing installed before I can work out exactly where I want it, I'm just making sure it will work in that position so I haven't got to allow for extra coax elsewhere.
Cheers Gibbo
You got it. You will find that it is not that hard to map out these wire and mount, runs and spots after you have the structure together. Laying and attaching wires with clamps or tie-ties is best done one you are that far along. You will be better able to adjust your mount locations once you have a structure in front of you. Many times where onc wire or mount point is intended to go will affect another item you wish to go in the picture as well and you will want to trial fit them as you go anyway.
Keep stirring that red dust and you will get there. Yours, R.E.A. III #80888
