Old 04-24-2017, 10:02 AM
Tom Gan Tom Gan is offline
Default 3D Printer GPS Antenna Glare Solution
Posting this to the forum in case anyone wants to consider this as a solution to GPS antenna windscreen glare. I have two GPS antennas that are mounted inside my tip-up canopy in my RV9-A. One is for the Skyview and the other one is for my GTN-650.
I've beeen flying with that annoying windshield glare from both white pucks for a while and from time to time I have considered painting both units flat black or putting a fabric cover wrap. There are mixed reviews on painting the Dynon and specifically called out not to paint the Garmin GPS unit.
Regardless, I wanted a solution that was not permanent and could be removed if I park on the ramp in the summer so that the GPS antennas don't absorb as much heat. I also wanted to be able to replace the cover if needed.
With all of that said, I picked up a 3D printer earlier this year and took a local tech school class in SolidWorks. With the free student edition available for EAA members I started considering projects to 3D Print.
A few weeks ago, I emailed the folks at Dynon and being their usual great customer support they posted their 3D model on their website.
The Dynon GPS antenna has compound curves and having their 3D model makes it very easy to create a shell in Solidworks.
I took a different approach to creating a shell with the Garmin GPS antenna. I just took the dimensions from their documentation and with a few
minor adjustments to the size, I create a model without compound curves.
Tried a few thicknesses of the shells and landed on 0.050in.
The printed models require supports so the pictures are right out of the printer without any sanding or prep. Since I printed using PLA vs. ABS I also spray painted the covers wtih flat black to give some UV protection.
I have not test flown with the covers on yet. Interested to see if putting a painted plastic shell on top of the Garmin GPS antenna vs. painting the unit directly (which is not recommended) has any effect. Another reason to make these removable if you are flying in IMC.
If you don't have a 3D printer there are numerous websites that will do the print for you as a service.
RV9-A QB
http://www.mykitlog.com/tomgan
Old 04-24-2017, 01:33 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default PLA
The PLA will warp when exposed to the heat of the sun.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 04-24-2017, 02:12 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
I am afraid the black plastic cover will simply radiate the heat it will absorb directly to the antennae underneath it. Preventing heat build up is the real reason Garmin does not want their puck painted. I think you would be better served if you were to just relocate the antennas to a different location to get them out of your view while flying.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 04-25-2017, 09:26 AM
AAflyer's Avatar
AAflyer AAflyer is offline
Default Paint it
I sprayed my Dynon puck with flat black paint...can't remember the brand or type. Seems to work fine.
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
2020 Dues contributed
Old 04-25-2017, 09:27 AM
spatsch spatsch is offline
Same here.
Oliver
Oliver Spatscheck
RV-8
N-2EQ
http://www.spatscheck.com/oliver
Old 04-25-2017, 09:19 PM
JordanGrant's Avatar
JordanGrant JordanGrant is offline
Second Paul's comment. I tried making some PLA stuff for my truck, and it essentially melted in the Las Vegas heat. It gets hot in there in the sun. ABS has held up well, though, so you might consider switching materials.
Jordan Grant
RV-6 N198G
Monthly donation started Mar '20
Old 04-26-2017, 05:31 AM
Thought about just painting the puck but I was concerned about the heat as others have posted so that is why I opted for the shell so I could remove it. Glad to see someone has painted the antenna without issue. I assume it is flat black or grey color.
The glare is mostly an issue when I have a passenger and they take pictures. I'll try the ABS route vs. PLA and see during the summer how things work out.
Thought also about relocating both of the antennas but wanted to experiment with an easier solution for now.
Thanks to everyone for feedback.
RV9-A QB
Old 04-26-2017, 02:53 PM
The easiest solution remains covering the antenna with a lightweight black cloth. The cloth can be a stretchy, somewhat open weave that lets air move, thus helps ensure minimal temperature rise. Total time to cover an antenna is about 5 minutes, and requires a pair of scissors, a bit of cloth and a bit of glue like Goop to hold the cloth to the underside of the antenna. Very easy to do.
Old 04-26-2017, 06:05 PM
Xkuzme1's Avatar
Xkuzme1 Xkuzme1 is offline
Try plasti-dip. If it doesn't work just peel it off.
RV-4 - 0-320 (160HP)
www.KCFlight.org
Tinker
ATP/CFI/II/MEI
N617TN
Old 04-26-2017, 06:13 PM
pitts flyer's Avatar
pitts flyer pitts flyer is offline
These may work too. FWIW...
Dave M
RV-4 finished, awaiting AW certificate
