Old 04-23-2017, 12:17 PM
Super Moderator
Default Nuts on carbs and fuel servos
While doing a prebuy on Friday on an RV-8 I noticed a nut missing from the aft fuel servo mounting stud. This is not the first one of these I have discovered missing on an airplane. I know standard practice has been to use a nut, a lock washer, and washer, but for many years now I have been using AN363 all metal stop nuts with a washer in these locations and I have never seen one come loose. You might consider it on your airplane.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 04-23-2017, 12:20 PM
RV6_flyer's Avatar
There was an RV-6A that had engine stop running a number of years back just short of KEMT airport. There were no injuries but the airplane was totaled.
The FI servo was loose.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 04-23-2017, 12:22 PM
az_gila's Avatar
az_gila az_gila is offline
Question
Would some blue Loctite be applicable here?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-23-2017, 12:43 PM
Super Moderator
Sure, that could be a solution, too.
Vic
Vic Syracuse
Old 04-23-2017, 02:03 PM
boom3's Avatar
boom3 boom3 is offline
Mine are installed "standard practice" but I've always kind of wondered about them and check them regularly. Nothing loose so far...
If you have a flat washer, a lock washer, and a nut aren't you essentially just locking the nut to the flat washer? I'm guessing this is why you brought it up. I wonder why this method is "standard practice" here.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 04-23-2017, 02:42 PM
SuperDave SuperDave is offline
I've always thought the same thing about the lockwasher on a flat washer...didn't make any sense. Also, it seemed silly that the airbox is safetied to the carb or servo but the carb or servo is not safetied to the engine. Always seemed bassackwards if anything.
Old 04-23-2017, 03:16 PM
longline longline is offline
Default Lock Washers
act as springs, so to speak. That is why we throw away the internally toothed lock washers after one use. There is not enough "spring" left in them to allow the plain nut to maintain torque if they are used again.
I agree with Vic that a metal self locking nut is probably better practice. I will admit to being concerned that a really tight self locker will unscrew the stud when you take it off... but that is why blue locktite was invented for the studs.
Old 04-23-2017, 04:08 PM
Super Moderator
I know, we've always heard that the lock nuts will pull the stud out, but I've never seen that happen yet (I know I haven't seen everything yet) and I decided a long time ago that the stud could be taken out of the nut in a vise if the stud came out and then reinserted back into the engine. Haven't had to do that yet.
You are absolutely correct on the internal tooth lock washers. Always throw them out when you remove them and use a new one.
Vic
Vic Syracuse
Old 04-23-2017, 04:43 PM
moosepileit moosepileit is offline
Stud length seems perfect for double nuts.
RV-6, bought from builder.
O-320, slider, carb, mags, FP
Old 04-23-2017, 06:13 PM
rvbuilder2002's Avatar
Though I have never found any loose if they have been torqued properly with new new lock washers at installation, piggybacking with a Palnut (google it) is another option for safetying critical course thread nuts.
Scott McDaniels
Hubbard, Oregon
