04-18-2017, 06:23 PM
Originally Posted by SMO
Originally Posted by N941WR
It depends on how you fly......
And the level of risk you are willing to accept. A plastic bag blocking the air intake can stop your engine, an alternate air source can keep it running.
You are 100% correct. However, many (most?) airplanes do not have an alternate air path. So, apparently many people, myself included, are willing to take the risk. Although I'm sure it has happened, I am yet to see a plastic bag blowing across any of the airports I have visited or at altitude.
I'm just thankful you didn't not mention having a bird go in the intake. If you are worried about that, then you should cover the canopy with a fence of some type because there is a better chance of taking a bird through the windscreen than in the air intake.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
04-18-2017, 06:59 PM
I bring it up because I believe that was my experience as related in this thread: http://www.vansairforce.com/communit...hlight=plastic
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
04-18-2017, 07:21 PM
Virtually all normally certified planes do have an alternate air path. It's a certification requirement, IIRC.
As an EAB airplane you are of course free to do what you please. But given how relatively easy and inexpensive Vans' alternate air design is, it seems penny wise but pound foolish not to install it.
04-18-2017, 07:36 PM
I do not know what the certification requirements for a new plane are but regarding your "penny wise but pound foolish" comment, I disagree. When I was building a lot of people put in the trap door that was held shut with a magnet. Some of these were suckered into engines. Thus Van's came out with the sliding door. If I remember correctly, there were similar issues with the slider. Thus, rather than risking my engine with a known failure mode, I elected to leave it off.
Bill R.
SC86 - Easley, SC
04-18-2017, 08:03 PM
The question.
If I were to be building with the installation of an IO-XXX "take your choice", I would as I have done, install Alt. air for the engine. We have it on our bird for all the good reasons that a Part 23 spam can dose. Just my two cents on the question. Yours, R.E.A. III #80888
04-18-2017, 08:18 PM
What about a carb engine with carb heat installed?
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
04-18-2017, 08:55 PM
If you use the stock design where the heated air is introduced before the filter, I'd put in the ALT air. The current pivoting plate door seems pretty robust.
04-18-2017, 08:59 PM
I have carb heat and didn't bother with the alt door. I also avoid taking off from shopping center parking lots.
I did replace the almost useless juice can heat muff for this from Wicks and actually see a noticeable RPM drop now.
It really comes down to your risk tolerance. Ask yourself this, "What are the odds of an intake blockage?" If you don't like your answer, install it
Bill R.
SC86 - Easley, SC
04-18-2017, 09:23 PM
This is the exhaust system I have and the heat muff. I do not think it is the best option for exhaust or how the FAB fits to the exhaust. I would not do it this way again.
https://www.vansaircraft.com/pdf/rev...ther/OP-54.pdf
I believe the carb heat I installed is acceptable risk for me and will not be installing the alt air.
rockwoodrv9a
Williamston MI
O-320 D2A
04-18-2017, 09:38 PM
Video
Here is a video of my alt air door in action. This is looking up at the bottom of the filtered air box, controlled from cable in cockpit. https://youtu.be/YhsEx4_Z9v0
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
