Old 04-13-2017, 09:28 PM
JDA_BTR JDA_BTR is offline
Default GARMIN Interconnect Question
I'm looking at the following components:
GTN 625 with separate GNC 255 COM/NAV
GDU 460/470 (one each)
G5
Looking through the drawings, the GNC 255 has one serial port to communicate with the rest of the system; I suppose it should be connected to the primary GDU? The drawings show a choice of any of the GPS-enabled items having a potential link to the radio. Is one the best?
Also, for the NAV side of the GNC 255.... Does the 460 or 470 have the ability to show DME, ILS/VOR, etc? How is the NAV radio data read back to the G3X system for use inflight? I think that it may not, but wanted to ask.... is the only way to get this done with a GTN650 having built in Nav/Com and more serial channels?
I see in the G5 docs that the VOR heading can be set with the G5 via a serial link, so I assume the same is true if the serial link is taken to the GDU 460 instead. That also implies the radio will send the VOR error for display back to the G5 or GDU 460 accordingly. Does that also apply for ILS? DME?
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 04-13-2017, 10:08 PM
maus92 maus92 is offline
G5
I think you're going to need a GAD 29 arinc box to port the nav functions of the GNC 255 to the G3X system. The G5 communicates over the CANBus in a G3X system.
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
Old 04-14-2017, 05:24 AM
The missing link..... thanks! I knew I needed it but it didn't click for me. Thanks!
Old 04-14-2017, 07:00 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello,
The GNC 255 doesn't need an A429 connection to provide VOR/ILS navigation to a G3X system including course selection on the PFD.
Just connect a single serial port connection from the GNC 255 to your PFD as shown on page 26-15 of the Rev. AB G3X Installation Manual.
We recommend you connect the MapMX serial interface from the much higher capability GTN 625 to the G5 serial port input like shown on page 62 of the Rev. C G5 Installation manual. Note that this same GTN serial output is also connected to the PFD.
With this installation, you could turn off both the GDU 460/470 displays and still fly an autopilot coupled LPV approach with the GTN 625 and G5, and of course fly an autopilot coupled flight plan entered on the GTN anywhere you like.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 04-14-2017, 09:45 AM
Originally Posted by g3xpert View Post
Hello,
Steve
Steve, does he still need the GAD 29 for the GTN? Can he push frequencies from the G3X to the GNC 255?
CA
Old 04-14-2017, 09:54 AM
g3xpert's Avatar
Post
Hello Charley,
Yes and Yes.
Page 34-128 of the Rev. AB G3X Installation manual explains the radio tuning support provided for the GNC 255, and it is quite extensive and integrated for a G3X Touch system.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 04-14-2017, 11:30 AM
What is the difference between the MAPMX format 1, MAPMX Format 2, and CONNEXT?
When the drawings are compared between different install manuals, the serial ports overlap in the examples. You've mentioned one instance where the GTN serial port feeds both a GDU (I have two) and the G5 on the same MAPMX (format 1?) output.
After wiring the GNC 255 to the primary GDU, I look at the example page 26-26 in the G3X installation and see the same primary GDU serial port called out for a GDU-GTN interface withe same serial port as called out for the GNC 255.
I suppose I can just tailor the docs to change the serial ports to accommodate everything but it would be super helpful if the documentation put some choices in it so a lot of cross-reference wasn't needed.
Are there other places (like the GTN->GDU/G5) serial link where one serial output feeds multiple inputs?
Old 04-14-2017, 12:10 PM
On further review....
On the drawing for my PFD (GDU 460), I am finding that I need:
Ser1 -> GTX 45R for ADSB data
Ser2 -> Nav/Com from GNC 255
Ser3 -> CONNEXT from GTN 625
Ser4 -> MapMX from GTN 625 (625 also sends this to G4 SerRx same signal)
I also have a GDU 470 in my plan. Each GDU has 5 serial ports.
The CO detector needs one. Should it go to the second GDU?
What else?
Looking at the Fig 2-2 page 2-3 of Rev AB G3X install, I need RS-232 from GDU to GMC 307. Haven't found that elsewhere in the docs yet
And yes, I am working with Stein to put in a panel but even if he gives me a nice drawing I want to know how it all connects up so I understand it. I also want to make sure I get every feature included..... I'm planning to wire it myself.
Old 04-14-2017, 12:19 PM
g3xpert's Avatar
Post
Hello JDA_BTR,
Yes, the installation manuals show one example of a serial port connection from one device (like the GNC 255) to a display, but don't show all possible combinations.
The first 5 serial ports on each of your GDU 460/470 displays can each be configured to connect to a wide array of devices such as GMC 305/307, SL30, SL40, GTR225, GNC255, GDL39/39R, GNS/GTN navigators, TIS traffic devices, GTX 45R/345 ADS-B receivers, third party autopilots, GTS 8XX active traffic system, GEA24 and GSU25 backup data buses, electronic circuit breaker, CO detector, lightning detector, and more. It wouldn't be possible for us to show all of these connections and never "overlap" in the example wiring diagrams.
The 6th serial port on each of your displays is on the P4601 and P4701 9 pin connector and is always configured to be a backup data bus for the GEA24 and GSU25 as shown on page 25-18.
For your system the GTN 625 serial port connected to the PFD and G5 is configured for MapMX Format 2 as explained on page 26-26. We would use a separate serial port on the GTN to provide a dedicated connection to the G5, but the GTN only allows one serial port to be configured for MapMX Format 2, so the transmit line on that GTN serial port is connected to the serial port input on both the PFD and the G5. This is the only serial port in your system for which a serial port is connected to two places.
Your CO detector may be wired to either GDU.
Oh, and we do have email and telephone customer support (see below) anytime you need to discuss specifics for your system.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 04-14-2017, 12:27 PM
Thanks Steve! Part of the educational process..... This has been very helpful.
