Old 03-26-2017, 10:56 PM
longline longline is offline
Default Dynon D-180 and fuel senders
Because I am planning to use auto fuel in my build I am going to convert to the float system from the previously installed capacitance system.
I am a bit confused by the Dynon EMS instructions concerning the fuel sending units. If you configure the Dynon for resistive, does the float systems from Van's simply need to be connected to pin 20 and 21, respectively, of the DB37, and the float bodies to ground?
This is exactly what Cessna did in the early years and, if so, I understand it. That system simply regulated the ground that the gauges saw.
Old 03-26-2017, 11:05 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Yes, that's exactly how it works.
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 03-26-2017, 11:30 PM
Default Thanks for the reply
Never thought working on all those old Cessnas would carry over to the RV8.
Old 03-27-2017, 08:51 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
I think it predates Cessnas and is more related to even older Stewart-Warner automobile gauges.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
