  #21
Old 03-23-2017, 05:08 PM
f14av8r's Avatar
f14av8r f14av8r is offline
Originally Posted by Michael Henning View Post
B&C.... wishing I got to fly the F-14.
Wishing the F-14 had a B&C alternator!
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (flying)
Flying an A320 to pay the bills
Exempt and gladly donating anyway - Current through March 2021
Old 03-23-2017, 06:17 PM
Fred.Stucklen's Avatar
Fred.Stucklen Fred.Stucklen is offline
Default PP ALternator
1360 Hrs on a Plane Power alternator with zero issues. I do have an air cooling tube pointed at the back side.....
Fred Stucklen
wstucklen1@cox.net
RV-7A N924RV Flying (1825 Hrs & counting)
RV-6A N926RV 875 Hrs (Sold)
RV-6A N925RV 2008 Hrs (Sold)
Old 03-23-2017, 06:26 PM
Jrskygod Jrskygod is offline
Larry post part number please.
RV-3 Rebuilding
RV-9 Flying and having fun, experimenting and having fun, did I mention flying and having fun?
RV-6A SOLD
Maule M5-235C SOLD
C-172G SOLD
Stinson L5 SOLD
Grumman AA1A SOLD
Old 03-24-2017, 04:17 AM
BlakeB BlakeB is offline
Default Problem Solved
So maybe I jumped to conclusions. My mechanic dug into the problem and found the plug that clicks in came loose. Plugged her back in a she works. We will see for how long..... Really appreciate everyone's quick replies!
Old 03-24-2017, 10:11 AM
lr172 lr172 is offline
The alternator that I used was a Lester # 14158
Larry
Old 06-03-2017, 02:35 PM
L'Avion's Avatar
L'Avion L'Avion is offline
Default Autozone 14118
To each his own - have seen Autozone alternator P/N 14118 running on IO-360:
http://www.autozone.com/batteries-st...=&model=&year=
Technical Service Bulletin
Outside ear to outside ear: 4 1/8"
Old 06-22-2017, 07:40 AM
L'Avion's Avatar
Default Workalble Alternator/Regulator Combo O-360's
I installed the Transpo regulator & the AutoZone alternator on my RV-4; had to fabricate an alternator bracket. Bracket: used 1' x 1 1/4" x1/4" flat stock steel; cut off two pieces 1 1/4" x 1 1/4"; welded one piece on the end of stock; bored holes in both pieces for alt. bolt(s); positioned second piece by bolting on alt; measured overall length of bracket to correspond with two alt. bracket holes and one stud hole on engine case. Measure & bore forward hole for attaching bracket, first - take your time & get that hole right. Height of two pieces to connect alt. might vary; measure carefully.
I installed the AutoZone alternator P/N 14118 on one of the retractable gear RV-4's five years ago, still going good.
CPGENERATOR.COM
12V FORD HD ADJUSTABLE VOLTAGE REGULATOR - preset @ 14.2v
Item# Transpo F540HD $26.99 USD
Shipping and handling $8.00 USD
$34.99
AutoZone Regulator also works:
http://www.autozone.com/batteries-st...30187_887935_0
Part Number: VR730 $ 23.99
Alternator/Autozone
1976 Chevrolet Truck Luv 1.8L 2BL SOHC 4cyl
http://www.autozone.com/batteries-st...34268_479962_0
Price: $35.99 Core: $10.00 Total: $45.99
Wiring as per Sam Buchanon:
http://www.vansairforce.com/communit...tage+regulator -page 1
“A readily available regulator that has seen widespread use on RVs is 1975 Ford LTD, available at your local auto parts store.
Wire it like this:
I -- no connection
A -- jumpered to "S"
S -- jumpered to "A", also connected to your alternator switch from the field CB
F -- connect to field terminal of your alternator
case -- securely bonded to ground (i.e. mount on firewall and insure good electrical bonding)”
Barney in Memphis
RV-3 & RV-4 flying
Saved by BasicMed!
Old 06-22-2017, 11:35 AM
unitink72 unitink72 is offline
Default 60 or 40?
Originally Posted by L'Avion View Post
Alternator/Autozone
I haven't seen that ALT mentioned before. Externally regulated - check. Fan appears to spin the right way. 60amps - nice. Strange thing is when you go to bbbind.com, their specs show it as a 40amp.
Either way a great find. Mind including a pic of your fabricated bracket?
Josh T
RV-10 #1750
N67SC reserved
http://n67sc.blogspot.com/
2019 Dues Paid
Old 06-22-2017, 01:25 PM
L'Avion's Avatar
http://www.delcoremy.com/Product/Details/14118 shows as 60amp.
Will post picture the next time the lower cowling is off; forgot to mention that this arrangement bit a small hole thru the bottom cowling - will have to add a small "bump."
Old 06-22-2017, 02:53 PM
L'Avion's Avatar
Default Mentioned Retractable Gear RV-4 - will be for sale, soon.
I have no info, seller will post in for sale.http://i32.photobucket.com/albums/d3...&1498164422290
For info on retractable gear, RV-4, contact: Steve Price, 901-277-7835, tullypilot@aol.com; aircraft will be going to Oshkosh.
