Go Back   VAF Forums > The Never Ending Debate Section > Primers
Old 03-15-2017, 04:18 AM
NZMA NZMA is offline
Default De Beer epoxy
Hi all,
Is there anyone who has used and can recommend the De Beer 1-7510 epoxy system.
I enquired with an industrial paint supplier about Akzo 463-12-8 or an alternative and they came back with this.
http://www.debeer.com.au/products/pr...y-primer-white
https://www.de-beer.com/TDS/au/TDS1-7520.pdf
Cheers
Tooling up almost complete. RV-7 on paper.
Old 03-15-2017, 08:09 AM
BillL BillL is offline
Default Not equal for 2024 Tx alloy
High concentrations of chromates give the protection for aluminum alloys with copper - 2024. Looking at the MSDS, this does not contain chromates (10% or so) and would not be equal in that respect. Scratch tests show non-chromates (with a few exceptions) preform much more poorly with this alloy which dominates the RV build.
Bill
RV-7
Lord Kelvin:
Old 03-15-2017, 09:52 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
It looks like the De Beers (Valspar) primer would be too thick for a general interior application.
It is being advertised as an easy sanding high build primer.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-15-2017, 12:00 PM
I did wonder about it being too thick. I'll give that one a miss.
Thanks for you input.
Old 03-15-2017, 01:18 PM
nzrv8's Avatar
nzrv8 nzrv8 is offline
Hey,
Since you're in NZ - Have you looked at Resene Durepox? I've used it on my RV-8 project, it is pretty amazing stuff.. And readily available at any Resene Automotive outlet..
HUgh
Paid up - Sep 2020
Old 03-16-2017, 02:51 AM
Thanks Hugh, that sounds like an option.
