Old 03-02-2017, 12:56 AM
bob888 bob888 is offline
Default Ignition question
I have a Slick 6393 mag on left and Electroair ignition on right. The Slick has retard points but I have no need for vibrator or Slickstart because the Electroair can start the engine. Question is what to do with the mag wiring so that it won't fire early and kick back. One possibility is to leave it off until after start but eventually someone will start with it on and potentially cause damage. What have others done about this?
Old 03-02-2017, 12:57 AM
I should add that I have toggle switches and not the usual key switch.
Old 03-02-2017, 07:13 AM
DanH's Avatar
DanH DanH is offline
Perhaps ground the magneto p-lead while the starter is engaged?
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-02-2017, 07:29 AM
Super Moderator
Personally, I don't like adding any complexity to the ignition switching. It is supposed to be simple and reliable.
Can you label it off for start? That's a first choice.
Another way, IF you feel you have to "move a switch" is to use a 3 position toggle, labeled OFF, START, RUN. The middle position will do nothing (you do have to remember to jump the poles on the back of the switch so the mag stays grounded). But it should prevent the switch from being thrown to the run position during a start.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 03-02-2017, 07:31 AM
Auburntsts's Avatar
The easiest solution is to start only on your EI and keep the mag off until the engine is running.
I have two mags and no EI, but the principle is the same. My left mag is a retard breaker and I start on that mag alone. I don't have a traditional keyed rotary ignition switch either so I manually select L, R, or Both for the mags but I do it with one rotary switch vs 2 toggles. My starter is a physically separate switch.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 03-02-2017, 09:07 AM
Jasonm Jasonm is offline
I have a similar setup to you and am using the keyed ignition switch like this one - http://www.aircraftspruce.com/catalo...?clickkey=5735
My Lightspeed is on the "Right" side and my mag on the "Left". I simply turn the key to the "R" position and start. The "L" position is not live while starting. To do my mag check I will move the key to the "L", observe the RPM change and then move the key to the "BOTH" position.
Jason McKay
RV-10
Old 03-02-2017, 10:30 AM
I'm pretty sure there's a drawing for this in the Aeroelectric Connection.
Old 03-02-2017, 10:42 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
This is really a wiring question, so I moved it to the correct forum----applies to virtually all models not just the 10
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-02-2017, 06:04 PM
Paul from Flyleds's Avatar
Paul from Flyleds Paul from Flyleds is offline
Aeroelectric article
We used two mags in the RV-10 and wired them as per Bob's method.
Paul McVitty
Flyleds.com
VAF advertiser
Old 03-02-2017, 08:57 PM
Thanks all. Second question for those with one electronic ignition and one mag...how much rpm drop is acceptable when the ei is cut out for a mag check? I'm seeing 150 rpm drop from 1700 rpm when I switch off the ei.
