Old 06-04-2015, 06:58 AM
BillL BillL is offline
I can only conclude that all these rods are not consistent hardness. I used a not-so-cheap die and it would not get more than 1/4" and snapped, popped and was a significant torsional displacement. I tried several dies, and high sulfur cutting lubes, it was unsuccessful. It was clamped in the vice close to the jaws too. I have tapped and threaded many thousands of things and could not get this job done. An experienced friend had a similar experience.
We got the stainless all thread rod from Grainger. I might use the safety wire technique, but have the rod on hand now.
Bill
RV-7
Lord Kelvin:
Old 06-04-2015, 07:13 AM
Edwardoc Edwardoc is offline
I used SS welding rod and a quality die to thread the rod if you want to go with the rod. Just requires a lot of back and forth so as not to bend the rod and oil. And you need the dog legs to clear the drain-back tubes.
Old 06-04-2015, 08:55 AM
AAflyer's Avatar
AAflyer AAflyer is offline
Default Doh!
Never thought of using wire. I got the store-bought ones bent, but the holes in the baffles look like they're drilled too close to the bend, that I don't see how a nut, much less a washer can sit flat. Safety wire may be in my future.
Thanks for all the feedback.
Back to the cowling?
cowling?
cowling...
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
2020 Dues contributed
Old 06-04-2015, 06:48 PM
Champ's Avatar
Champ Champ is offline
Used a good quality split die. You can start it out a little more open then tighten it down. Still lots of back & forth to clear chips.
Dennis Enns
Kingsville, ON
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, Hartzell CS, dual PMags.
2020 Donation In
Old 02-25-2017, 08:59 PM
jwilbur jwilbur is offline
Default Old thread, comment and new question
First, I may have stumbled onto a way to make cutting the threads onto the rods pretty easy. After having the same difficulties described here, I happened on one that was EASY. It just spun and cut the threads with almost no effort. After examining what I had done differently I realized I had started the threads as usual, got about 4 threads on and took a rest. When I put the die back on I accidentally put it on backwards with the narrow opening of the die first. I intentionally did the same thing on the remaining rods and all were trivially easy to cut. ... Hard to get started but once I had about 4 threads with the wide opening of the die first, I flipped the die and went to town. ... Maybe this might help someone else in the future.
Now for my question. Standard IO-540 D4A5 for the RV10. Followed the plans, interpreting best I could. The pictures below are of my left and right outboard tension rods. As I tighten the ends the rods bow upward in the center putting pressure on the oil return lines. Am I doing something wrong? These are the second set of rods I've made. Increasing the angle where they attach to get more clearance makes no difference. They just bow up in the center and contact the oil lines. In the pics I've backed off the pressure to the point where I can just move the sheathing. If I tighten to the point where the baffles are tight against the cylinder fins, there's enough pressure on these return lines to see them flex upward. This just doesn't seem right to me. But maybe it's OK??
Am I missing something here? Any advice?
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
Old 02-25-2017, 09:02 PM
DMFenster DMFenster is offline
Old 02-25-2017, 11:37 PM
Redrock's Avatar
Redrock Redrock is offline
I was able to buy SS all thread from my local RC airplane hobby shop. I slid it in plastic tubing prior to bending for oil return tube clearance. Worked great!
Brad Smith
Dues Paid Apr 2018
RV7A Tip Up, flying (the sports car)
IO-360, dual PMag, WW 200RV, dual Dynon SV
PA28-235B (the truck)
Old 02-25-2017, 11:46 PM
Doesn't the center of the rod bow upward against the oil lines as you tighten it? It seems for me to get it tight enough to make the baffle lay firmly against the fins the rod is putting a lot of upward pressure on those oil return lines. Am I making the rods too tight? Am I just overthinking it? ... I just don't like seeing the oil line flex as I tighten the tension rod. Seems like a bad thing.
Phase II - 11/2017
RV-10 Build Log
Old 02-26-2017, 10:46 PM
Redrock's Avatar
Hi Joe,
I had to 'over bend' the jog so the rod just touches as it gets tight. I also used brake line tubing over the rod to protect the return tube from rubbing.
https://www.dropbox.com/s/woj5oxmkbl...F5573.JPG?dl=0
https://www.dropbox.com/s/ka638gn8il...F5574.JPG?dl=0
https://www.dropbox.com/s/rff4h3nuqt...F5575.JPG?dl=0
Brad Smith
Dues Paid Apr 2018
Old 02-26-2017, 11:08 PM
Redrock's Avatar
Joe,
After looking at your pictures closer, I think you need offsets/jogs closer to where the return lines are. Just bend a relatively short section near the lines to go down and then back up near the tubes.
Brad Smith
Dues Paid Apr 2018
