  #11
Old 02-13-2017, 06:28 PM
BruceP BruceP is offline
Default Update?
Allan, any update on your progress?
Bruce Peters
Bakersfield, CA
RV-9A, Flying 11/21/15
VAF#1145
Donation up to date 08/20
Old 02-16-2017, 03:30 AM
cderk's Avatar
cderk cderk is offline
Default TCW Tech
Can this be used?
http://www.tcwtech.com/control_valve_servo_kit.html
RV10
http://n688cd.wordpress.com
Old 02-16-2017, 07:32 AM
TJCF16's Avatar
TJCF16 TJCF16 is offline
I have an oil cooler shutter that I took off my RV9A. It has all attaching hardware and cable. Would be willing to part with it.
Tim Crouch
RV-9A N626TC
"Merlin"
Old 02-16-2017, 09:05 AM
PerfTech's Avatar
PerfTech PerfTech is offline
...In process and shouldn't be much longer. We are keeping a list and will let everyone know when soon. Thanks, Allan...
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 02-16-2017, 11:37 AM
TCONROY's Avatar
TCONROY TCONROY is offline
To prevent the common baffle cracks, I mounted my oil cooler on the firewall and put a butterfly valve inline with the SCAT that goes to the inlet of the oil cooler. Works extremely well in the colder months and I have been told that it cuts off more air than the shutter.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
Old 02-18-2017, 01:07 AM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Allen,
I would like one of your oil cooler slider plates for my RV-12....also, by chance would you be making something of the same sort for the RV-12 coolant radiator?
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 02-18-2017, 12:13 PM
gerrychuck gerrychuck is offline
I use the nonstop aviation butterfly; I believe this unit is exactly the same, as Cleaveland took over selling them after nonstop went out of business. Mine may be the 3" version though:
http://www.cleavelandtool.com/4-AIR-.../#.WKiYXRgZPq1
I love it. I mounted mine between the rear baffle and the scat tube, and I have been really happy with it. With the knob in the cockpit, I can control my oil temp to a degree or two range very easily in flight. I understand one poster's concern about another cable through the firewall, but I find I am often adjusting in flight, so personally I really like having that ability.
Gerry Julian
Moose Jaw Saskatchewan
RV6A "Second Wind" C-GERZ (born N242UL)
O-360 A1A, Sensenich FP prop
Those who think any system is foolproof greatly underestimate the ingenuity of fools
Old 02-18-2017, 12:33 PM
Fred.Stucklen's Avatar
Fred.Stucklen Fred.Stucklen is offline
Default Oil Cooler Shutter
How about just using a wood working Vac system shuttle valve shown below. I mounted my oil cooler on the firewall and use this one.
It appears that Van's no longer sells the oil cooler shutter. Does anyone know of anyone else who makes and sells one?
Fred Stucklen
wstucklen1@cox.net
RV-7A N924RV Flying (1825 Hrs & counting)
RV-6A N926RV 875 Hrs (Sold)
RV-6A N925RV 2008 Hrs (Sold)
Old 02-18-2017, 12:50 PM
JonJay's Avatar
JonJay JonJay is offline
For those considering the Shutter Type, they are not free flowing when open. When the Shutter is wide open, the flow is restricted and you will have higher oil temps than without the Shutter.
For many of us, this isn't a problem. I installed the Shutter for Winter ops as my oil temp was too low. The Shutter raised the Oil Temps adequately for most Winter ops in our neck of the woods. It also raised Oil Temps in Summer but for my particular situation, it still does not present a problem as even on the hottest days, I operate well under spec.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-18-2017, 04:36 PM
Phantom30's Avatar
Should not be a problem...in Idaho, even in Summer, my temps are not very high..
Ric Dickison
307 (CAB) Phantom
Tho RVN)
2018 Dues Paid
