02-06-2017, 06:33 PM
When that data sheet says max discharge rate is 40amps, and it also says "short circuit protection", one could conclude that when used as a starter battery, the protection system should think of this event as a short circuit and shut it down, but apparently it doesn't. Hmmm
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
02-07-2017, 02:33 AM
LiFePo and Pmags
I'd not seen this thread until today - just been having a read through and comparing with my own experiences.
I Fitted a LiFePo battery to my Pitts in 2013. (The Pitts is IO 0-360 / Injected with 2 Pmags.)
4 Years later I have had Zero issues - other than the reason for this post.
Right from the outset, I had some starting difficulties in cold weather. After much head scratching and battery changing it turned out that I was getting a voltage drop when cranking that made the P mags see less than 9 volts. If this happens they re boot and wont spark until they have seen a full rotation. With the LiFePo4 battery the engine would still crank at acceptable speed, but the voltage dropped over the compressions.
Once the problem was identified I have used a work around solution of a small dedicated battery to the Pmags. 4 years later and all still works well.
I remain a fan of the battery technology - It's the cheapest way of reducing aircraft weight out there (other than going on a diet perhaps). Just thought I'd mention the voltage drop experience in case anyone else has a similar issues.
02-07-2017, 11:50 AM
120A no problem
I've done test discharges to verify cold cranking amps of this battery with battery tester. Simulating an engine start (which is 100A on my little engines 1200W starter), I did 120A for 15 seconds no problem. I allowed the battery to rest for 30 seconds and it did it again, three times. Voltage was still >14.4VDC without charging.
I love a good experiment.
I'll continue to evaluate it and report back.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
02-07-2017, 12:02 PM
Another vendor is this one:
Next Gen Battery
I spoke with these folks as well and they say 100A is rated peak discharge for 30 seconds, which is the definition of cold cranking amps.
Ron Gawer
02-07-2017, 12:27 PM
Originally Posted by Aggie78
I'm talking about the one Ron is using...By The Lithium Battery company.
And, I'm just relaying what the folks answering the phone told me.....
I just got a phone call back from Ron at "The Lithium Battery Company" on the use discussed in this thread for their LBC-20 battery.
Not designed for this type of service, and it is not a suggested or authorized use, just like the conversation with them yesterday.
There will be no support or warranty given...With any kind of problem, you will be completely on your own...
Still looking for one that will fit in the Van's battery box that holds the PC-680 but not the EarthX.
Rob Schroer
RV-7/N75WV
YIO-360-M1B
New Braunfels, Texas (KBAZ)
VAF Monthly Donor
02-07-2017, 12:41 PM
Originally Posted by rv7charlie
But using anything outside its design parameters is...an experiment. The poop sheet on that battery explicitly states that maximum draw should be less than 40 amps, and max continuous should be less than 20 amps.
If you're talking about the Shorai battery, it's CCA is 270amps - well over the max pull from the starter at about 200amps. Continuous approaches zero while the alternator is operating, and my electrical analysis spreadsheet shows a 12amp draw in the event of alternator failure.
>500 hours of operating in MN summers (>90?F), winter (<0?F), VFR/IFR, Day/Night, acro (incl. IAC and mock aerial combat) and zero failures. A complete discharge due to leaving the master on. It's still going strong...
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
02-07-2017, 12:56 PM
Did Ron explain why?
Common sense says they're not giving up the whole cranking battery market without good reason.
Dan Horton
RV-8 SS
Barrett IO-390
02-07-2017, 01:23 PM
Bevan
Unless they mean 40 amps per cell, with 4 cells in parallel which would give 160 amps - but it's certainly not stated that way.
02-07-2017, 02:46 PM
Love these batteries!!!
...Over 6.5 years, and 1000 plus hrs. with lots of abuse. No issues to date.
I am very happy with the Shorai battery and saved 23 lb over the 925 I removed. Thanks, Allan
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & ServicesInfo@AntiSplatAero.com Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
02-07-2017, 03:06 PM
The Shorai batteries look like very good options, and cost effective. I like it.
Ron Gawer
