Old 01-24-2017, 03:05 PM
j_omega j_omega is offline
Default Where to have instrument panel cut?
Where is the most cost-effective place to send a panel design for manufacturing?
Old 01-24-2017, 03:08 PM
Carl Froehlich's Avatar
Why not do it yourself? If you can build a plane you can build your panel.
Carl
Old 01-24-2017, 03:12 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Carl
Agree with this---in fact I just started making a new section for my panel this morning.
But, to answer your question ...........
Stein does them. http://www.steinair.com/
Up North does too. http://www.upnorthaviation.com/contact-me.html
I think Aerotronics does them. http://www.aerotronics.com/
I think Walt also. http://www.expaircraft.com/L-3.htm
Just to start the list.
Check yellow pages for water jet cutting shops in your area-----wherever that happens to be.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-24-2017, 03:17 PM
YellowJacket RV9 YellowJacket RV9 is offline
You definitely can do it yourself. I elected to use Upnorth Aviation http://www.upnorthaviation.com/
Less than $200 and he worked with me back and forth until I had a layout I was happy with - and since it was all CNC-cut everything fit perfectly. I'm sure had I done it myself I would have made 1 mistake somewhere that I would be staring at the rest of my flying life...I used xpanel software to do the layout.
Chris
Chris Johnson
Old 01-24-2017, 03:22 PM
Jrskygod Jrskygod is offline
Up North for mine - same results as above.
RV-3 Rebuilding
RV-9 Flying and having fun, experimenting and having fun, did I mention flying and having fun?
RV-6A SOLD
Maule M5-235C SOLD
C-172G SOLD
Stinson L5 SOLD
Grumman AA1A SOLD
Old 01-24-2017, 03:33 PM
Paddy's Avatar
Paddy Paddy is offline
Default Water Jet
I designed my own using Visio, converted it to a CAD file and paid a local water jet place $100 to cut it out. Turned out exactly as intended.
RV-10 N415JS
Slow build kit #40874
Homebuilt Kit Champion Oshkosh 2019
Atlantic crossings: 2
Old 01-24-2017, 04:06 PM
Mark Albery's Avatar
Mark Albery Mark Albery is online now
I've just had one cut. I found a local sheet metal fabricator with CNC laser cutting (Eclipse in Redwood City).
I planned it out in CAD and sent them an iges file. They cut it all for $100 cash including the #6 screw holes with nice clean edges. I had been quoted $300 for water jet, possibly a slightly better kerf, but I was very happy with the result.
Old 01-24-2017, 05:03 PM
tim2542 tim2542 is offline
Ditto! Most or all the avionics dealers will have the cad file for their devices available for download. Spend a few months contemplating the layout if you can, and bounce it off experience flyers for suggestions.
Then email it to a water jet shop and you'll be amazed at the precision you get for about $100. There is a radius minimum with WJ, but its pretty small and shouldn't be a factor. Example: I have a few 1/4" switch holes in the panel, they were drawn and cut with the anti-rotation tabs. These are very small and turned out functional but less than perfect. For everything else its fantastic, takes about 20 min to cut.
BTW, laser CNC shops near me agreed to do it, but said with aluminum there would be a slag mess to clean up when done, and suggested WJ instead.
Tim Andres
Old 01-24-2017, 05:08 PM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
Chris
+1 Great customer service
David
EAA 1250 KPTW
Royersford, PA
david@rv12pilot.com
2020 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 01-24-2017, 07:26 PM
Jesse's Avatar
Jesse Jesse is offline
I use a laser shop in Orlando and they do superb work. Everything comes fitting perfectly. It needs to start as a good CAD file, though. Laser is MUCH cleaner than water jet. I have used both, and after using the laser shop, I wouldn't even consider using water jet again.
Jesse Saint
