Old 01-17-2017, 07:20 PM
jdmunzell jdmunzell is offline
Default -8 QB Fuse recommended working height
Christmas in January finally arrived!! My -8 QB Fuse kit showed up and I haven't even started the inventory yet, meaning the plans/manual are still buried somewhere within..
Curious about how others have started this part of the project as far as working height goes. How how off the ground is best for the fuse? Seems like I read somewhere of someone building a rotisserie for the fuse project to make it easier to reach in.
Also, I see where some folks get the gear on fairly early...
Thots...??
Jeff
-8 wings, finishing up
-8 QB Fuse just arrived!!!
Old 01-17-2017, 08:36 PM
xblueh2o xblueh2o is offline
Longerons a little lower than waist high.
I have had mine in a rotisserie about that hight and then also down lower sitting on milk crates. I liked the rotisserie hight better for most things.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 01-17-2017, 09:55 PM
Robin8er Robin8er is offline
Id say 2 feet off the ground. Mine is on a normal table and in instantly regret all my life decisions up to this point.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 01-17-2017, 10:55 PM
MartinACFactory's Avatar
MartinACFactory MartinACFactory is offline
Default Built a support frame for fuselage
Hello !
Just sharing...Please see my build thread here: http://www.vansairforce.com/communit...=127826&page=4
My fuselage is slow build, but I am now at the as "delivered quickbuild stage". I didn't have a suitable table to build my airplane on. Thus, I made myself a support frame that will become eventually my transport dolly. I also added some benches around the frame, such that I can either use them to put tools on or climb on-board the fuselage.
I also plan on making a rotisserie later, once everything is riveted final.
Martin
Martin Leroux
CPL ME-IFR & CFI Class 3, 1,400+ Flight Hours
Terrebonne, Quebec, Canada
RV-8 s/n #80414
Kitlog: http://www.mykitlog.com/MartRV80414/
Empennage: 100%
Fuselage: 95%
Wings: 99% (Flaps remain to attach)
MD-RA Pre-closure inspection completed Dec 27, 2019
Entering Final Assembly Phase !
Old 01-18-2017, 03:20 AM
goatflieg's Avatar
goatflieg goatflieg is offline
At the recommendation of Tony Partain, I purchased two Werner Alum Pro Deck Work Platforms from Home Depot. They stand 16" tall; the platforms come in two sizes and are rated at 225 and 300 lbs. I bought one of each. My QB fuselage is in Oregon awaiting shipment; we'll see how the platforms work out. I've also considered one of John's Rotisserie Kits from Heartland Machine & Mfg. The previously shared Shopify link for purchasing one has expired; not certain of the current status of that company. Wally Anderson (Synergy Air) suggests that's not really necessary; you can do everything fairly well with the fuselage about 2' off the ground.
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - currently working on finishing & firewall forward.
N657AR reserved
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2020... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 01-18-2017, 05:48 AM
Veetail88's Avatar
Veetail88 Veetail88 is offline
For the most part I worked with a pair of jack stands under the wood blocks bolted into the spar box that the fuselage shipped with. I could adjust the height as needed and it worked out. Were I to do it again though, I'd definitely take the time to build a rotisserie. Reaching in rather than bending over and reaching down has got to be easier.
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 01-27-2017, 01:22 PM
AAflyer's Avatar
AAflyer AAflyer is offline
Default Make it spin, baby!
I used an auto engine stand from Harbor Freight as a rotisserie, and never regretted it. Along with a rolling, adjustable-height stool, I could comfortably reach most places in the fuselage with it rotated 90 degrees. This was PRICELESS during the wiring stage...which will come soon for you.
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
2020 Dues contributed
Old 01-28-2017, 04:17 AM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
What Bruce said!
I would highly recommend that you either build or buy a rotisserie jig for your RV-8 fuse. Rotating the fuse 90 degrees from the upright position provides easy access to floors, longeron areas, wiring, etc.
IMO a rotisserie jig and an adjustable height stool are a must have and a real back saver.
Mike Draper
RV-8 N468RV
First Flight 11/13/2011
TMX0360, Pmags, CS
Bridgewater, MA
KPYM
Old 01-28-2017, 05:03 AM
wilddog wilddog is offline
Everything AA says!
Old 01-28-2017, 05:44 PM
Default Sounds like rotisserrie is the way to go!
Thinking I'll go to a rotisserrie. It doesn't appear to be terribly expensive to make and if it'll save what's left of my back...... Probably Harbor Freight's version..
Jeff
